Steeda ultralite input?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Digital_Synapse
Mass Effect Field Expert
San Antonio, TX
2015 Triple Yellow Mustang GT PP
Yes, you have the early version we still offer both, the choice for road racers is running the early version with the 3/16 inch rear spacer. The reason we don't have the drag race look on our handling springs is because we like more 50/50 weight distribution for handling. The more you jack up the rear end, the more weight you transfer to the front wheels which is not desirable for optimum Handling.
Check out this article below by one of the most respected critics, Evan Smith in the Mustang and S550 market.The vehicles featured had the early Ultra-lights.
http://www.mustangandfords.com/even...-at-the-track-guys-camp-steeda-driving-event/
The only spacers on the site are 1/4" and 3/8"...there are no 3/16" that I see.
tj@steeda
Timothy
What can I help with - send me an email to [email protected] & I will get you squared away.
Best Regards,
TJ
tj@steeda
Timothy
p.m. sent
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
I'm ready to order but need some clarification on some details.
Sorry for the delay, just preparing for the Hurricane.
The spacers are only available in 1/4 and 3/8 we did a last minute change to the dimensions. They will raise the rear almost double the thickness of the spacer. Also. they will work with all aftermarket springs that fit into the upper production spring seat.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
PM replied
[MENTION=13598]Gibbo205[/MENTION] care to chime in?
We work in mm over here, due to a leverage ratio on the Mustang you get:
6mm thickness = 10mm height increase.
8mm thickness = 12mm height increase.
10mm thickness = 15mm height increase.
12mm thickness = 18mm height increase.
I went with 8mm on my car, perfect stance, I'd recommend 6mm or 8mm thickness spring spacer for use with ultralites in the rear.
Performance nut
TX
2018 Mustang GT A10
Any news on the front spacers? How much do these weigh? I'm wondering if they offset the weight savings of going to ultralite springs.
Gibbo205
UK
A spring spacer is polyurethane it literally has no weight, maybe around 200-300grams.
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
Quick question.. If I wanted the front lower, could I remove the lower isolator on the perch? Or would that cause noise? [MENTION=25806]SteedaTech[/MENTION]
Gibbo205
UK
DO NOT DO THAT! Yes it would cause more noise but it could also cause suspension failure.
If you want lower, buy different springs.
HISSMAN
Large Member
West Virginia
That's what I figured. I have bought suspension setups before that listed the isolator as optional. Was just wondering how it would be on this car.
