Burnin4
- Apr 6, 2015
- Mooresville
- 17 GT350
F1, I'd give Tim at MPR a call. He can build you a 1000hp short block for $5000'ish (fresh block and crank, diamond pistons, mahle rods, king/clevite bearings, ARP hardware, balanced). Then, I'd send him your heads/cams/front engine pieces. Anytime heads come off a motor they need/should be disassembled, cleaned, resurfaced, with new sprangs and valves, gaskets/studs. I'd let him assemble the entire engine and ship it back to you ($2000'ish). It'll be a sure thang, mine makes 1100'ish on 23psi however anything over 800/13psi is useless on the skreet. MPR engines are sure things, guaranteed.
