Spare 2020 GT500 Remote
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Has anyone had any luck getting a working 2020 GT500 remote off of eBay or Amazon?
I bought one off of eBay when I first got my car, but was unable to program, and I had to return it.
Any help would be appreciated.
Earl
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Earl
I can tell you the one I purchased through my friend at Ford was very tricky to program, but it was eventually done. It came down to the directions in the manual not being "balls on" accurate. Event the position of the fob in the hole made a difference.
Perhaps there is still hope for the one you bought.
Tomster
Beware of idiots
Tom
Yes, the programming is tricky as hell. It has to be done down to the gnats ass. I plan to buy a fob off ebay and program it. It wont be a GT500 fob, because they cost way too much. I will use just a regular mustang fob. I will let you know how it goes when I get my car back.
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Earl
I just found this for a 2019, I would assume its the same for a 2020 (maybe not) but here it is just in case:
How to Program a 2019 Ford Mustang Keyless Entry Remote Fob Smart Key
Step by Step How to Program Instructions:
Programming a Spare Intelligent Access Key
Note: You can program a maximum of four intelligent access keys to your vehicle.You must have two previously programmed intelligent access keys inside your vehicle and the new unprogrammed intelligent access keys readily accessible. Contact a local locksmith to have the spare key programmed if two previously programmed keys are not available.
Make sure that your vehicle is off before beginning this procedure. Make sure that you close all the doors before beginning and that they remain closed throughout the procedure. Perform all steps within 30 seconds of starting the sequence. Stop and wait for at least one minute before starting again if you perform any steps out of sequence.
Read and understand the entire procedure before you begin.
  1. Remove the rubber covering from the cupholder. Place the first programmed key in the backup slot at the bottom of the cupholder, then press the push button ignition switch.
  1. Wait five seconds and then press the push button ignition switch again.
  1. Remove the intelligent access key.
  1. Within 10 seconds, place a second programmed intelligent access key in the backup slot. Press the push button ignition switch.
  1. Place the unprogrammed intelligent access key in the backup slot and press the push button ignition switch.
Programming is now complete. Verify the remote control functions operate and your vehicle starts with the new intelligent access key.
If programming was not successful, wait 10 seconds and repeat Steps 1 through 7.
Tomster
Beware of idiots
Tom
I just bought this fob on ebay. Its a basic mustang fob, but it will work. $45 delivered. I'll let you know how it works.
Ebay item 174326867797
Tomster
Beware of idiots
Tom
That sounds about right. The procedure is in the owners manual. You are probably correct that it is the same procedure.
It used to drive me nuts. It has to be done exactly. I recall the last step or two was critical.
AngelDeath
CH, New Jersey
Let me know if it works, cause I was looking for an extra key for use so I can put the two that came with the car away.
Tomster
Beware of idiots
Tom
There were 12+ available and the price was good. Its just a beater fob. The trick is to always have 2 master fobs. If you loose 1 and you are down to one master, you have to have the dealer do the programming and it is expensive as hell.
So program your spare, and put the two masters away in a safe place.
AngelDeath
CH, New Jersey
Exactly and as soon as you say it works I'll be heading to your ebayer.
Tomster
Beware of idiots
Tom
It will be at least a week. I'm having xpel done. I can say with confidence that it will work. I looked at the fcc id and the Anatel part number. The only issue is the steel key won't match, you'll have to get a blank and have it cut (or not), and it won't have the cobra emblem.
Other than that, its a 5 button mustang fob. You are pretty safe to buy it if you don't want to wait a week.
Tomster
Beware of idiots
Tom
And besides, free returns within 30 days.
Snoopy49
Snoopy49
California
Earl
Thanks for the item number. Let me know how it works out. Are planning on getting an emergency key, I noticed the one that was included with the fob was already cut (used).?
Tomster
Beware of idiots
Tom
Yes, they are used fobs. You can buy a cheap blank and have it cut
Jmeo
You said member ;)
Massachusetts
Jaime
I would take the physical cut key out of one of your original fobs, and place it in the ebay fob. You are buying the fob to use in place of the original fob, so you don't ever loose one of the two master fobs. Even if you loose the ebay fob with the original cut key in it, you wouldn't have to go to the dealer to get a new key cut.
My point is, getting a spare is about the fob, not so much the key inside it, so you may as well use the original keys. If you use the cut key once, I would be surprised.
AngelDeath
CH, New Jersey
Ebay Item: 313179640050 $49.95 New with a Blank key in case anyone is interested.
