dbmonster
- Mar 12, 2015
- United States
- 2015 Ecoboost
Thank you for taking the time to compile all this info in one post!
Any aftermarket DP will decrease back pressure vs stock so if the PCV is allowing pressure in the crankcase at idle and oil backup into the turbo it will smoke.Has anyone reported smoke with the livernois highflow race downpipe
But wont a cat catch the smoke?Any aftermarket DP will decrease back pressure vs stock so if the PCV is allowing pressure in the crankcase at idle and oil backup into the turbo it will smoke.
It can lessen the smoke but if there is enough it may still be present. The car may also have enough back pressure to stop the smoke as well. It really depends on the engine and the PCV of each car.But wont a cat catch the smoke?
Sent from my SM-G900P using Tapatalk
If the cat is catching the smoke, it will eventually fail. They are not designed for that, and will probably eventually melt or clog with carbon.But wont a cat catch the smoke?
That's the correct size for a mishimoto, don't know about others.What size check valve do I need? 1/2"?
Just the opposite. Boost is coming from the intake manifold, so if you don't want the catch can to see boost, the check valve goes between the intake manifold and the catch can.I installed my catch can this week end and realized the upr dual valve does not have a check valve on the dirty line coming off the pcv. If deleted wouldn't that pressurize the catch can under boost?
1/2" (12mm) I bought a UPR one off ebay for cheap. Yes it goes from the can to the intake manifold. CAN OUT --------> CHECK VALVE (--->) ---------> INTAKE MANIFOLDi already have the mishimoto catch can. do i put the check valve in the side that goes from the can to the intake manifold? Also what valve should i look for, can i pick something up from lowes or ace hardware.
Do not get anything from a hardware store, get a check valve that is made specifically for this purpose. I went with one from Boomba, it was around $40.i already have the mishimoto catch can. do i put the check valve in the side that goes from the can to the intake manifold? Also what valve should i look for, can i pick something up from lowes or ace hardware.
