Memphis-EcoStang
- Mar 8, 2017
- Vancouver, WA
- 2016 Impact Blue Ecoboost
OK- To start with- NO blue smoke at idle. Getting ready for a tune, put in new plugs, tb spacer, manifold spacer. No blue smoke. Figured this was the time to install passenger side and driver side catch cans-and now I get blue smoke occasionally, some days none, and other days looks like my trunk is on fire. Put the original hoses back. No smoke.
I have double and triple checked hose routing, tried adding a UPR crankcase breather (which made smoke worse), I have no CEL's, engine feels like it is running smoother than before and pulling harder.
Reading through the multiple threads on blue smoke (yes I tried to read them all, there are a lot) It looks like I need to pull the manifold off, gut the PCV system and insert a check valve? Is this correct? My other thought was ordering the Radium engineering PCV Baffle Plate which has a built in check valve. Pro's and cons to either?
****UPDATE******
And..... My car is F^%%%$! possessed. Last two days no smoking in long trips or stop and go traffic... What the bloody hell?! I have to assume either there was some coating in the catch cans or that I was overly liberal in lubing the hose fittings. Still, already ordered the Radium plate, so something else to fiddle with
****UPDATE******
