Smallest Pulley P1SC Stage ll
whatsup62
Jupiter
What's the smallest pulley you guys have ran on the P1SC-1 stage ll. And boost psi if known. Looking at 3.85"
r1lovin
colorado
2015 Gt
I ran a 3.40 on s 6 rib lol. Send it.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
What are the technical differences between the p1sc stage 1 and stage 2?
Dedicated 8 rib drive (can run the p1sc all the way up to F1r on this bracket setup), larger intercooler and optional upgrade to red bypass valve.
whatsup62
whatsup62
Jupiter
Noticed someone in Florida has a car with a stage 2 P1sc with a 3.85 pulley, makes 14psi at 7000.
Yep..talked to PC that maxes out the P1SC-1 basically. That's the one I will be running before spending the $$ on another head unit.
Bartly
Out West
What’s the psi difference between pulleys? Is it 1 psi for every 1/8” reduction. Mines puting out 8.75 psi with the large stock 4.75” pulley.
whatsup62
whatsup62
Jupiter
That's what is was basically on the HO....started with 3.8 ( 7.5 - 8psi) and ended with a 3.4 (10 -11psi).
whatsup62
whatsup62
Jupiter
That’s gonna be one hot puppy at those RPMs
Not a whole lot more than what it is now....by the calcs with the 3.4 pulley on the HO kit the impeller speed is 61319 at 7500 rpm...with the 3.85 on the stage ll its 63896 at 7500. P1SC-1 maxes out at 65,000 rpm.
ahl395
Allan
I believe [MENTION=20966]diablomatt[/MENTION] has a P1SC with a 3.7 or 3.8 pulley and makes around 14psi. Overspinning the blower a little bit though I believe. With the help of meth injection he's around 800whp.
Check his thread here: https://www.mustang6g.com/forums/showthread.php?t=99231
whatsup62
whatsup62
Jupiter
Great...good read...Thanks.
I saw [MENTION=20966]diablomatt[/MENTION] is running 93...are you also?
Hoping the E85 helps a bit with cooling,not wanting to go the Meth route if possible.
ahl395
Allan
Im on 93 + meth running a P1X at 15psi and 20* timing.
With E85 you'll have no issue on 14psi. Meth is really only needed if you're stuck on 93 and trying to run more than ~12psi. E85 is the preferred route.
ProChargerTECH
Boostville
2015 Mustang(s)
They are decent right up to the redline.
However over the redline ya, then the temp goes up.
So even if a person makes 1-2 more psi, they will gain nothing at the track.
Since the power is lost due to drive power, and temp. :)
Hence why I always shake my head at guys "over spinning" blowers.
And bragging about boost numbers.
If your car goes 144mph at 13psi
And 144mph at 15psi
Well, stick with the 13 ;)
