Should I build my MT82 or go automatic?
Mikes_Slow5oh
Utah
2015 Ford Mustang 5.0
So right now I’m at the 800WHP mark. My end goal is around 1300WHP. The car is a manual right now and I need advice on if I should just build the manual or if I should go ahead and do an automatic swap. If I should go automatic should I build a 6R80 or go TH400? What’s your guys’s advice?
daSNAK3
Cary, IL
Jake
2021 GT
What do you want to do, row gears or not row gears?... lol
NGOT8R
Adrian
2019 Bullitt
Build your MT82 and weld the shift forks. If you really want to make it strong, Cryo treat all hard parts.
Swtbabybilly
Mamaroneck ny
Will
19 gt
What's your goal with the car? Do you want the fastest possible time at the track then go auto, want to keep banging gears and have a blast every time your drive then build the manual, I will personally have a manual sports car till im to old to deal with a clutch, best of luck which ever way you go
Berserk
Phoenix, AZ
2023 GT
Save the manual.
Autos :yawn:
bKennedy
Chapel Hill, NC
Bob
2018 Mustang GT PP-1
With the horsepower you are looking at you will tear that 10R80 apart. The MT82 may not handle it either but it will be easier, and cheaper, to put a strong 6-speed replacement in rather than an automatic built to handle that much horsepower.
Mikes_Slow5oh
Mikes_Slow5oh
Utah
Okay who should I look to get the built transmission from? If I go 26 spline how much will I have to replace? I already have a twin plate clutch so if I go 23 spline will that hold the HP goal I'm trying to reach?
Swtbabybilly
Mamaroneck ny
Will
19 gt
You can go Ben calimer, or tremic is coming out with a direct replacement for the mt-82 id look into that, best of luck
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
I went 26 spline Ben callimer Mt82.
NGOT8R
Adrian
2019 Bullitt
Slow Yote
Central Ohio
Seth
2018 GT PP1
Auto for speed
Manual for fun.
The Watchman
North of Indy
2022 Mustang GT
T56 Magnum swap and call it a day. The t56 will hold up for quite awhile at that type of horsepower
TreaF18
Kentucky
Trea
2020 Mustang GT
I’ve got a 2020 that i’m currently in the process of putting a T56 in. I’m curious how you ended up wiring the transmission in? I’ve got the bowler harness but have read that it will not work with 2019+. I know that the Digi-Gear module is close to being finished so that I can retain the rev match/reverse camera, but I would at least like to drive the car around temporarily until that module is released.
The Watchman
North of Indy
2022 Mustang GT
That is a tricky install for sure. My setup is a 22’ GT and we have the t56 in right now.
My shop was Finish Line Performance in Loveland Ohio.
They installed a special module which tells the PCM the car is in a single gear.
I have no backup camera or rev match. That being said, I would not ever wanna go back to a mt82 Eve a fully built one
T56 Magnum XL is superior in every way. Did you see Tremec has recently come out with a direct OEM replacement for s550?
