MT82 Won't go in gear
blvkstang
St. Louis
Dino
Hello,
I just bought a new to me 2016 GT PP with a manual transmission. 24 hours into owning it and about 30 miles into spirited driving, I was locked out of gears. While the car is on, I cannot get it in gear, the pedal is spongy and if I start it in first (it shifts fine when it's off), the car wants to go forward. I'm thinking it's the master clutch cylinder, have one coming in from Ford already, but I'd like to hear your guys' opinion, what could it be?
jcl78
Denver, CO
2016 Mustang GT Premium / PP1 / MT-82
Sorry to hear that, from what I have read on here most likely the clutch let go. It seems a real weak point when it gets hot, stress fractures form and it shatters. Could be from misuse from the previous owner, it was already fatigued.
blvkstang
blvkstang
St. Louis
Dino
I would really love to believe that it’s just the master cylinder. I did find some fluid on the rod though, not sure if there should be any.
jcl78
Denver, CO
I hope so too, let us know what you find.
mustang1
Dallas, TX
probably clutch. If I was to buy a used Mustang, I would assume the clutch might go bad and factor that into an offer.
TrevorGT
WI
race red 2015 GT
It’s the clutch. Been there more than once on the stock clutch.
Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
Yup my first thought reading that was the clutch went out.
Hopefully it’s just the cylinder though.
CompOrangeFanatic
Delaware
2015 Mustang GT Premium /2019 Toyota Camry XSE V6
My educated guess would be the clutch itself or the slave cylinder. Shortly after having the power pack 3 installed and shifting at 7500 rpms, I started having issues with the stock clutch. Everytime I got on it hard, the clutch pedal would go to the floor and stay there for about 2 minutes and I had problems shifting into 3rd at or near redline. I replaced the clutch, slave cylinder, flywheel and installed the stainless steel clutch line. Problems are now gone.
Kong76
Turlock, Ca
2016 Ingot Silver GT
I'm on my second oem clutch with 34k miles. Made in Turkey... There's the problem.
If it is the clutch while your in there, replace the tob, pilot bearing. Have your flywheel surfaced or replaced if bad. Tob, pilot bearing are like $127, $14. Piece of mind.
blvkstang
blvkstang
St. Louis
Dino
So a quick update. I replaced the master cylinder rod part, whatever it's called lol, the part that's connected to the pedal. Anyways, long story short, nope, that wasn't it, after bleeding the system and starting the car, nothing has changed, still can't go into gear and this time I can actually smell my clutch burning so yep, ordered a new triple disk clutch kit, just to be safe, new flywheel, new tob, pilot bearing and a braided clutch line. Taking it to the local shop as soon as the parts come in and honestly just awaiting for the moment I'll be able to drive it. Thanks everyone for your help, I just didn't wanna believe that it's the clutch lol, oh well, it is what it is.
Kong76
Turlock, Ca
Sounds like a solid setup. More than likely headed this same direction soon. Minus the triple disc. Ill just go a twin disc spring hub.
Dablue5.0
California
Xavier
2015 mustang gt pp
Hello guys I have a 2015 gt pp
My clutch went out at 54k
Replaced it with exedy Mach 500 stage 1 organic clutch kit with the hydraulic throw out also got the McLeod stainless steel clutch line another thing that I added added Was the Barton hybrid 3 short shifter connected to the tranny .. now that I got it back I noticed that shifting goes gotten harder, so I adjusted the shifter feels nice when the car is off when it’s on I noticed that it does want to go in gear I kinda struggle but it’s funny cause it doesn’t do it all the time, well most of the time .. what do you guys think it mite be or had any experience with this..please let me know. thanks
only_1
United States
Your clutch likely isn't fully releasing. Get a vac pump on the brake reservoir and bleed it out. Just don't leave it on for a long time. It can mess with the brakes - Found that out firsthand.
Dablue5.0
California
Xavier
2015 mustang gt pp
So that means that the person who worked on it did not bleed the hydraulic throw out the proper way?
