Sequential shifter on a Tremec T56 M XL
Beano
Melbourne Australia
Phillip
FGX XR8 and 2016 Mustang GT, Both supercharged
Hello Guys,
Have anyone any experience on or considered using a (mechanical) sequential shifter on their manual gearbox?
Something such as here: https://www.s1sequential.com/product/sequential-shifter-t56-magnum/
I am planning doing a replacement of my M82 to a Tremec T56 Magnum XL, was wondering how well these work with a Tremec.
edit: Bremer is another (more expensive, but possibly better?) unit ->
Appreciate your feedback.
Cheers,
Beano
EFI
Masshole central
5.Br0
I get the whole sequential part of it in the shifter, but what happens to the clutch pedal? Do you still have to use it every time?
If you do, I imagine that is the "slowest" part of the equation so physically moving a lever faster won't realistically decrease shift times if you still have to do the same action of disengaging and engaging of the clutch manually through the pedal.
Beano
Melbourne Australia
Phillip
Normal clutch-operation remains...
ponie1992
Elgin, SC
2016 Ruby Red PP GT
A sequential shifter should eliminate most chances of missing a gear. You still have to use the clutch, but only making one movement of the shifter for every gear change. No more navigating the gate, the shifter does it for you.
EFI
Masshole central
5.Br0
Can you change through several gears in one shot, or do you have to engage every gear say going down?
By that I mean, can you disengage the clutch while in 6th, downshift 3 times to 3rd and then engage the clutch?
ponie1992
Elgin, SC
2016 Ruby Red PP GT
Very good question! I'm not sure, but I'll try to find out.
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Yes, each action results in a shift. You could hold the clutch in and do as many actions as you want up or down to get in whatever gear you want. Thats's where a gear readout gauge comes in handy.
ponie1992
Elgin, SC
2016 Ruby Red PP GT
The shifter I'm looking at can be optioned to include a gear indicator.
shogun32
Northern VA
This seems to be an odd choice with usage restricted to drag racing in order to minimize throw complications. With the traditional you don't have to look at anything to know what gear you're in. With this you either have to remember/ascertain from speed vs engine RPM or look at an indicator.
Now an actual sequential transmission would be a useful thing.
ponie1992
Elgin, SC
2016 Ruby Red PP GT
I don't understand what the difference would be. With a sequential trans, you'd still have to have some type of indicator of what gear you're in or remember it yourself.
shogun32
Northern VA
A sequential transmission is built radically different from a traditional - you literally can NOT skip gears. All this retrofit is doing is changing an H-pattern into a click-clack toggle at the knob. At the business end it's doing the H-pattern for you.
ponie1992
Elgin, SC
2016 Ruby Red PP GT
How is it any more useful?
shogun32
Northern VA
