Tremec T56 Magnum Xl 2.66 or 2.97?
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
Which one is Best for my setup 2015 GT with 2.9 Whipple 331 Gear ratio
Looking into upgrading into T56 Magnum XL which is best suited for my setup. 2.66 or 2.97? :cheers:
whatsup62
Jupiter
Definitely the 2.97. Not sure you will even be happy then with a 3.31 rear! I had 3.73's and they barely worked. Stepped up to the 4.09's and they work great. With the 4.09's it is about the same as a MT82 car with 3.31's.
RoadCone
Ohio
2016 Competition Orange PP
I also went with the 2.97 and 4.09 gear combination. I loved it NA with the CJ, but have yet to run it with the Whipple.
EFI
Masshole central
5.Br0
I would say depends on the type of driving you do. I imagine even with the 2.66 and 3.31 gears your Whipple would put down more than enough torque to make it fun on the street.
For an all out drag car (or NA/centri setups) it's all about gearing so 2.97 for sure. For a street car with a twin screw 2.66 would be more than fine.
RoadCone
Ohio
The problem is taking off and stalling it. When I had my 3.73 and the Tremec, it was just hard to take off without over-reving, I was NA, but I would think this would still apply.
EFI
Masshole central
5.Br0
One I think the addition of a Whipple will help with that. Also, I can start in 2nd gear just fine and only bring up the RPMs to about 1000-1200 and it starts going. Maybe you were on a hill when you were having a tough time taking off without over reving because even a 2.66 first gear Tremec has more pulling power than a 2.43 second gear Getrag.
A perfect example is the 13-14 GT500s, they have a 2.66 Tremec with 3.73 gears and I don't think I've seen anyone complain that they have issues starting from stock. I've driven my friend's car and I could get going on flat roads without even giving it gas...all I did was just slip the clutch slowly and it would go.
I would agree that a Tremec and 3.73 gears is a bit too much (or too little gear) for an NA car, but for a whipple setup that would not be the case.
rio16
rio16
MAD_50HH
Bay Area SJ, CA
Rio
Thank you for the great info and experience. I will def give it a thought. Thank you so much. :cheers:
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Yo [MENTION=13292]rio16[/MENTION] you want my 3.73 diff if you get an xl?
