Sai Li fuel system thread
beefcake
Bethel
2018 Ford Mustang
with the fore you do not need a controller, can be done with all wires and relays, but the controller is nice
PowerAdderGT
Mustang
So what would I be looking at then for 1k rwhp E85, Fore triple hat with dual pumps, -8 feed and fitting to use stock line as return. Would you need rails? Anything else?
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
For 1000hp I would do rails. You will also need a controller. 3 pumps get the fuel pretty hot when running all the time.
beefcake
Bethel
2018 Ford Mustang
pm sent
its personal preference on using the controller,
def would do rails for 1000 wheel
you can always start without rails and upgrade later, nice thing about the fore setups
zaquhree
zaquhree
Orlando
2015 S550 GT
Looks like this thread should keep growing. Car needed some attention Saturday so I didn't get the install started
Should be starting this Thursday
Heard the stock lock collar is hard to get off
zaquhree
zaquhree
Orlando
2015 S550 GT
She's installed and pumping fuel.
Have a few gooooood tips to help everyone out.
Took a bunch of pics too.
Had a leak that I'm tightening up as well as soldering my last two connections that are crimped
zaquhree
zaquhree
Orlando
2015 S550 GT
Dialed it in on e85.
Took it from 10-15psi and fueling looks perfect all the way through on e85!
zaquhree
zaquhree
Orlando
2015 S550 GT
yes sir. took it up to 7k and fueling looks good. going to do a full pull past 7k today to see if fueling stays flat. seeing 20-22* of timing on E85 and it feels faaaaaaaaaaaaaast
fueling on 11-12psi to 7500 is flat out the back
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Lol, it sure does feel fast. I couldn't get the smile off my face Friday when I was finishing my 100oct tune with KenB. The difference from 93 to 100 or e85 is huge. But, I would go with a little more timing for the track than 22 degrees with only 11 - 12 psi.
zaquhree
zaquhree
Orlando
2015 S550 GT
I can say the difference from 100 octane to e85 is almost as big from 93-100 depending on how he ramps in timing with your blower.
Jon said I should be 730-750 on 11psi and e85 through auto and well over 800rwhp on 14-15psi and I couldn't stop smiling lol
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I'll post a pic of my timing in a little bit.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Here is a log from my 100 oct tune; WOT pull from 3600 to 7800. Overall timing is in column E. This is at 13psi. I'll see what it runs next weekend. But, I only have NT555Rs; haven't had a chance to get better tires lol.
Start of pull
[/URL][/IMG]
End of pull
[/URL][/IMG]
sonic
NY
Prius
WOW! This has me wanting an E85 tune. I still have my X4 im wondering if I can keep my Whipple tune for gas and swap to a custom E85 tune? Does anyone know if the X4 will save the whipple tune as my Stock file? Sorry for the off topic question
zaquhree
zaquhree
Orlando
2015 S550 GT
Start of pull
[/URL][/IMG]
End of pull
[/URL][/IMG]
....holy shit that's an aggressive ramp. You would see only the gains as a results of e85 burning cooler and lowering the intake temp (probably 15-20rwhp and 20-30rwtq over the file you have there just cause of the fuel change). 7800rpm lol I love me some OPG.
What does lambda look like up there? .80?
IAT at 100* through a pull? meth at work??
