return-less fuel systems thoughts and ideas
Midwestracer
Fayetville Arkansas
chris
2018 mustang gt whipple
I would like to open a discussion on your guys thoughts and peoples setups that have done it. Im new to the s550 platform and even semi new to fuel injection and FI my current setup is 2018 a10 tkm short block with gen5 3.0 whipple tuned by RPG out of tenn it has a GT350 dual pump setup with a dual jms BAP, fore rails, and on a 3.625 it made just over 800rwhp. I live in the ozarks and enjoy driving my car around here and can run it low on fuel and it seems fine i also drag race it.
@engineermike
@Angrey
@WildHorse
@mejohn50
@bankyf
SheepDog
Colorado
Dax
I would like to open a discussion on your guys thoughts and peoples setups that have done it. Im new to the s550 platform and even semi new to fuel injection and FI my current setup is 2018 a10 tkm short block with gen5 3.0 whipple tuned by RPG out of tenn it has a GT350 dual pump setup with a dual jms BAP and on a 3.625 it made just over 800rwhp. I live in the ozarks and enjoy driving my car around here and can run it low on fuel and it seems fine i also drag race it
That discussion is already well underway over here:
https://www.mustang6g.com/forums/th...-oem-style-bucket.165841/page-13#post-3937753
I would have gone this route if it were available when I bought my return system from 1979
https://www.beefcakeracing.com/kpmmus1500pwm-18-lhd/
Midwestracer
Midwestracer
Fayetville Arkansas
chris
Midwestracer
Midwestracer
Fayetville Arkansas
chris
Midwestracer
Midwestracer
Fayetville Arkansas
chris
2018, 22v bap, dw400 Whipple on the 3.25 pulley (15-16 psi), e85. Works well for me.
I’m also running a Roush f-150, 18v bap, stock pump, 12 psi boost, e85. It also works well.
My buddy is running a setup like mine but 3.375 pulley (14-15 psi), 18v bap, dw400, e85, also works well.
this is engineermikes setup FYI
SheepDog
Colorado
Dax
Who tuned these for you? Most if not all email tooners wont even touch FI setups that do not have a return system
engineermike
La
2018 GTPP A10
I tuned them. @mejohn50 is running a similar setup.
Both my car and the other mustang upgraded from 18 to 22v BAPs and saw only modest gains. The owner of the other car is an electrical engineer that decided to get to the bottom of it. Bench testing showed the DW400 flow went up a lot with that voltage increase, but it didn't play out in the car. What he found was that the stock power wire that supplies power to the FPDM and, thus, the BAP was losing nearly 2 volts. I think he's going to upgrade the power wire to see if that helps.
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
Are people not doing this? It was one of the first things I did, even before installing my BAP. The wire upgrade was super common and recommended by companies in the 3 valve days. Kenne Bell had it in their install instructions for their 3v blowers
It might be a placebo but it felt like the throttle response is much better after the wire upgrade on even a stock setup
engineermike
La
2018 GTPP A10
@illadvised I don't know of anyone doing running a bigger power wire to a BAP on a modern mustang. This is just a plug-n-play BAP and whipple-supplied DW400. We all wanted to see how far we could go without installing an expensive fuel system that makes so many sacrifices. I'd say we went further than we expected. Other cars running my pulley on e85 are making 850 rwhp +/- and I'm holding solid fuel pressure.
I even tried this on 39 lb injectors as an early test. I was able to confirm that the gen3 pcm will cut throttle if it runs out of injector, that is unless your tuner hooked you up by defeating this protection.
Pistol_91
Clearwater
2020 mustang GT
Do you think upgrading the wire would change the lift pressure in my application?
engineermike
La
2018 GTPP A10
I don't *know* if it will help in his application. We didn't know this voltage drop was this bad until earlier this week. It's possible that there is some other "smart" limit in the BAP so the bigger wire wouldn't help at all. Hopefully we'll know more in the next few days.
illadvised
San Diego
Brian Spilner
That is interesting, I would love to hear about how far you get. I would be interested in a 91 octane tune if you are tuning anyone else? I have 1050x, a dw400, upgraded wire, JMS BAP and a truck manifold. I wanted dual fuel system, but really like being able to pass smog with an afternoons worth of work.
It's really easy to do, and I felt it made a throttle improvement. All you need is a 12v relay, good gauge wire and some cheap electrical connectors. Heat shrink if you want it to be good
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
They are not brushless. That is the only thing I wish they did different. With that being said, running the pumps on the PWM controller has some similar benefits to brushless. I don't believe anyone has a brushless PWM setup that can be controlled by the PCM. While I agree that brushless is the way of the future, I know of more than a few 300k mile cars still running on the original brushed pump. Aside from that, the quality of this kit is nicer than the OEM parts it is replacing.
engineermike
La
2018 GTPP A10
It's about tapped out on the 3.25 pulley on e85, at my voltage and desired pressure. The lift pump duty cycle is 100% and pressure is falling to around low 60's in cold weather. It holds better in warm weather. But at ~850 rwhp on the street, I'm not sure how much more I really need.
That said, I am running stock GT500 "55#" injectors. If you really wanted to push a single brushed deadhead system to the limits, you could upgrade to the 1050's and drop the desired pressure to around 40 psi (in addition to upgrading the power wire). Math says you could drop a few pulley sizes further with these changes and possibly be in the 900+ rwhp range.
The problem is that, unlike the big tuners, I don't have a repository of tunes I could pluck from and send your way. Each car is its own science project and can take months to get how I want it.
I love that mine will pass smog and make ~850 rwhp how it sits today. Flex fueling, GT500 cats, and nothing emissions-related is disabled in the tune or on the car!
engineermike
La
2018 GTPP A10
At least one company claims to sell a kit that does this. I figured out the wiring and programming some time back but never did it. It seems possible but you're right, very rare if at all done.
