Required Upgrades for E-85?
NGOT8R
Adrian
2019 Bullitt
You give them too much credit. It had little to do with "trust" and was more "I'm sick of getting additional ticket requests" and they ran the numbers and realized that people were continuously asking for additional support when they employed the flex tuning. They make more money selling the canned, fire and forget other setups and so that's their choice (and frankly I respect them being honest). If you want flex fuel, just find another competent tuner who's willing to support you.
I wouldn’t say that I’m giving them too much credit, I was just pointing out that I had seen Alex provide an explanation for this on YT.
I wish I weren’t locked in with Lund only as a tuner, because I’d definitely like to try another tuner. I guess I was fortunate not to have any tuning issues with my setup that required lots of ticket requests. Tbh, I’m pretty happy about that.
The only way Iā€˜d be able to get tuned by someone else would be to start all over with equipment, plus the cost of tuning for 93, Flex, E85R and Nitrous (which is expensive). If my nGauge ever goes bad and I can’t get it back up and running, then I’ll try a new tuner and tuning device.
GL95
SC
2019 Mustang GT
the Proflex commander isn’t something you need, you shouldn’t be blending fuels or trying to use ā€œflex fuelā€œ on a forced induction coyote, you should run an E85 tune full time, if you want to run e85 full time. a drop in pump, with or without a voltage booster isn’t sufficient to runne85 in a forced induction coyote either, you need a return stupyle fuel system with a pt least 2 pumps. If you don’t want to spend $2-3k (minimum) for a decent fuel system, then you shouldn’t be trying to runnE85.
You can do it without issue with a can bus flex sensor. We aren't living in the 80s anymore
GL95
SC
2019 Mustang GT
This is the reason I would never buy a tuner specific device
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
There is at least one tuner who is using Fords logic with boost and non return fuel system and it is working fine.
Gen 3 ECU is very good
NGOT8R
Adrian
2019 Bullitt
Which tuner is that? I’ve been back and forth about adding a SC or turbo to the Bullitt (while retaining the nitrous system, but jetted for about 50 hp) and would like more info on this tuner and what the fuel system requirements are. I’m currently running a DW400 and JMS BAP and new fuel line that is E85 compatible.
Please PM me info if you don’t wish to post it here on the open forum. Thanks
cbrtrx
tampa fl
2016 mustang gt
What can be done and what is offered like mentioned earlier is very different. Lots of things are capable but it's just not cost/time effective so the major companies won't offer it. They are a buisness trying to make as much money with the least time invested. In the Ford world there is very little "custom" tuning. It's all copy and paste from a main file that a calibrator made 5 years ago now on the gen 3, then one of the employees there will just make very small changes if needed and send it back. They have no interest in learning new things or applying new strategies.
I use to offer a switch on the fly nitrous tune for coyotes to go from an NA tune to a nitrous tune instantly all the way back in 2011 when they came out but it just wasn't cost/time effective for me to keep offering it.
NGOT8R
Adrian
2019 Bullitt
I completely agree with this. I’m sure there’s almost always more that can be done to just about any tune to make it better, but like you said, it takes time to do it.
Having said that, as much as these tunes cost, I believe the time should be put in by the tuners to give each customer the very best that their combination has to offer. Now, that’s not to say spend an I definite amount of time on each tune, but the main things that can hold a car back line clutch protection/torque management, shift points and low to mid range drivability for sure need to be done.
K4fxd
NKY
Like any other tune once the first one is vetted the rest will use the templet with minor tweaks.
Personally I would not want a return system on a current mustang due to the limited capacity of the tank. 50 mile range is not worth it, unless a drag only car IMO. If drag only I would rather have a fuel cell.
Some tuner should follow Mikes lead and offer a true flex tune for FI and stock type fuel system.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Not so much as it's very good it just controls 16 injectors. So I'd imagine E85 wouldn't be a problem.
engineermike
La
2018 GTPP A10
I’ve had the opportunity to look ā€œunder the hoodā€ of quite a few oem, canned, and custom tunes. I’m often quite shocked as to what I find.
Some big tuners just lock the cams to some non-optimal cam timing for cruise and sacrifice the fuel economy vct buys you. I understand we aren’t in this game for the fuel economy, but there’s no advantage to this other than just ease of tuning which benefits the customer none. Some even lock the cams at wot, which hurts power or torque.
The coyote pcm has the ability to pull timing with boost, charge temp, coolant temp, lambda, etc. The stock tunes pull timing if it goes lean at wot. Most tuners disable this and some reverse it. Yes, some popular aftermarket tunes actually add timing if it unintentionally goes lean.
The gen3 coyote pcm is ridiculously capable and most tuners don’t even scratch the surface of what it can do. I mean, who wouldn’t want to vary the boost as a function of learned ethanol %? Who wouldn’t want it to pull timing if it goes lean? Who wouldn’t want individual cylinder knock retard? Who wouldn’t want it to pull timing if the cams don’t follow commanded angles? And why not offer torque-by-gear or torque-by-drive mode if the customer wants it?
GL95
SC
2019 Mustang GT
Use a fuel hat and that's not an issue
WildHorse
N/A or GO HOME
Puddintane
'17 S550
let's see those tables in a stock gen3 coyote mustang PCM .
engineermike
La
2018 GTPP A10
I actually believe that lack of access to the fuel line volumes is what prevented commercial tuners from offering flex tunes for Gen3, and lack of ethanol %-based timing is why they don’t on gen2.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
