Replacement axle nut different
Blufc3s
Quispamsis New Brunswick Canada
Stew
15 Mustang Premium GT PP1, 2003 BMW Z4 3.0 Manual
I am replacing my axle nuts 2015 GT PP.
The ones that the Ford dealer sold me are significantly different than the ones on the car. The new ones look like the ones sold on LMR.
The new ones have the right thread and 32mm nut size but the shoulder is significantly smaller in diameter.
Has anyone else experienced this?
Blufc3s
Blufc3s
Stew
moffetts
San Mateo CA
Black Whippled 2015 GT PP
I don't think it changed, but a lot of people have problems with them coming loose. There's numerous, very long threads on here about it. Unofficially, the recommended torque is 150 plus 1/8 of a turn.
Blufc3s
Blufc3s
Stew
Thanks, I’ll probably add some red loctite as well.
2016 Mustang GT PP w/ Voodoo
Yup they’re different. Gave me pause when I replaced a hub last year.
replacement part hasn’t fallen off the car yet so you should be good.
boB
boB
2019 GT PP1
Ford specifies (2019 service manual) 85 lb*ft and 30 degrees. The nut already has thread locking compound applied.
Blufc3s
Blufc3s
Stew
Thanks
El_Centenario
5L V8PWR
Apple Valley , CA
David
'15 Mustang GT Triple Yellow
Will be ordering a pair because the stock ones keep coming loose no mater how much red loctite I use.
boB
boB
2019 GT PP1
The question here is: did it really loosen? Did the nut actually turn from where it was installed? With red loctite this should be almost impossible. Or did the joint loosen? The joint (axle to hub) is a light press-fit splined connection, with almost no chance of rotational movement that would work to loosen the nut. It may be more likely that something in the joint compressed and in that case no nut, loctite, cotter pin, etc will prevent the problem.
El_Centenario
5L V8PWR
Apple Valley , CA
David
You definitely have a point there. I did mark the nut to see if it actually loosened up and it was right on the mark when I checked over the weekend. Would it be possible that I overtighten the nut causing the wheel hub to compress the bearing assembly? I check for play in the hub and it is definitely solid, no play in any direction. I just cant figure out where the popping/cracking noise is coming from. It occasionally does it when I back out of a parking and then move forward.
boB
boB
2019 GT PP1
It is not likely the bearing assembly is being compressed, maybe a soft washer, imperfect machining, ?
Scott
King City, Ontario, Canada
Scott
2018 GT Premium PP1, 2008 Mustang GT/CS, 1970 Boss 302
Say when you replaced your Hub, do you remember what the torques specifications were for the four 15mm bolts that secure the hub? Tried searching and have not been able to find it.
Scott
Scott
