Rear toe link nut size
Stangfan78
Virginia
CT
2021 Mustang GT
I’m installing Steeda rear toe links and I lost the nut for the bolt that holds the end at the knuckle. Does anyone know the size of the nut? I’m trying to find one locally before I call Steeda. I checked Home Depot but nothing they had fit.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Do you still need help with this? I may have those bolts as spares with which I can check the thread spec.
But if you have an Ace hardware nearby, and if it is as well-stocked with fasteners as is mine, then I suggest you take your bolt down there and find a matching nut.
Honestly, if it was me, I would order the OEM nut from a dealer, or online. It has the washer head, nylok insert, and geomet material (all at a price).
Stangfan78
Virginia
CT
2021 Mustang GT
Thanks for the response. I was able to find one.
Stangfan78
Virginia
CT
2021 Mustang GT
I ended up going with the Ford OEM bolts
WD Pro
United Kingdom
Lime GT
I’m pretty sure it’s a high grade M14 (standard pitch) plated nyloc flange nut.
Spanner size is unimportant if you are buying non OE, but I seem to recall my OE nuts being 22mm.
Side note : if you have the standard rubber toe link / knuckle bush, it’s very important to clock it. I dropped about 6mm per side from clocking that bush alone :like:
WD :like:
Magony15
Northern Illinois
2015 GTPP Base/Prem, 2009 Ram 1500
M14x2.0 My MMR new toe links didn't even come with those nuts. Ordered flanged yellow zinc ones from Belmetric.com.
WD Pro
United Kingdom
Lime GT
1.5 is not compatible with 2.0 (thread pitch) :like:
WD :like:
Magony15
Northern Illinois
Reuse your existing eccentric bolt and nut. The M14x2.0 nut is to replace the nut that is welded to the factory toe link.
WD Pro
United Kingdom
Lime GT
If M14 x 2 is correct, eBay item number 185758496322 :
WD :like:
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
the PP toe links don't have a nut and is integrated like you mentioned. Non PP toe links have a bolt and a nut
