Rant: F@#%ing Corrosion again!
moosestang
FL Keys
Gary
2018 GT Vert
So, I had a '13 that had some corrosion on the hood when I traded it for a new '18. Three years later, it's back again! Corrosion starting in the exact same place, left front of the hood lip. I hoped Ford could figure out how to paint aluminum by now, but no joy. I'll see what the dealer has to say at the next oil change.
Crowd Hunter
Tennessee
$hitbox
Where are you located that corrosion is such an issue? Never had a problem with it here in Tennessee.
BMAGOO
Alberta, Canada
2016 Mustang GT/CS, 2016 Explorer Sport, 2015 Ram 1500 Sport, 1968 Firebird
It doesn't have anything to do with location. It's because the aluminum wasn't prepped properly before paint. There is a TSB for it on quite a few Ford models. I got the hood on my 2016 Explorer replaced.
Crowd Hunter
Tennessee
$hitbox
That's just odd. My 2019 sat on the lot from 11/18 until I bought it new in 4/20, and was flawless. It was still flawless when I sold it last month. Maybe Race Red resists corrosion.
fmc_smt
Cottonwood , Arizona
Still should be covered under warranty. But hope you have a better repair then mine. Proper repair is to replace the hood.,
moosestang
moosestang
FL Keys
Gary
2018 GT Vert
I do live in a salt rich environment. I'm on a causeway with saltwater bays on both sides. A strong east wind will leave a salt film on the car, especially the windows, and I have to wash it frequently. But I'm inclined to go with the TSB theory that the hood was not prepped properly.
The corrosion appears as blisters. The paint doesn't appear broken, it's like there is something under the paint pushing it up. There are some stone chips in the hood that I've covered with touchup paint, and they are not blistering. You'd think these areas would be most vulnerable since the paint protection is compromised, but they are not. So it's off to the dealer.
BMAGOO
Alberta, Canada
When I got my hood replaced a couple years ago, there were two other Explorers in getting their hoods replaced as well. They told me they were doing lots of replacements and just a repair doesn't work.
I think it's TSB 19-2026 : Aluminum Panel Corrosion
ModularKid21
‘15 GT
I’ve seen a bunch of s197’s and a few s550’s with corrosion. I briefly read this thread yesterday and though to myself, I’m glad I don’t have this issue on my car. Changed the oil today and found some corrosion on the underside of the hood back by the passenger side hinge. Dammit
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
There is - it is aluminium oxide. Unlike rust it doesn't cause structural weakness as it is only on the surface, but it does make a mess and is difficult to 'fix' once started. Plenty of threads on here about it and the causes. Under warranty it will be a new bonnet (hood)
Gregs24
Greg
That will be down to electrolytic action between the aluminium hood and the steel hinge (aided by a paint defect or water ingress). Needs treating quickly if you are to save the hood.
v8hgt
Cheshire, UK
Nick
Race Red GT PP Coupe
They seem to go on the leading edge of the front wheel arch (fenders) as well as the hood. 2015-2021(current)
Rapid Red
Woodstock GA
Greg
What's going on over in the UK to be having such corrosion problems ?
Rapid Red
Woodstock GA
Greg
I don't think it is any different here to the US regarding aluminium corrosion problems.
Aluminum usually produces and leaves a white powdery trace, not rust ?
ORRadtech
Atlanta, Georgia
By definition aluminum cannot "rust". Rust is the oxidation of iron or steel. Aluminum can oxidize but it's not "rust" because it's not iron or steel. I don't believe anyone has specifically named oxidation in aluminum?
