Radar/Laser Detector
MROCGUY
AZ
2016 Mustang GT Premium
i have a Uniden R3. it's an older one, but it has some really great detection range. i got a hit 2 miles out. thing went off, i looked at the odometer after about 2 miles and there he was
Clintro
Clearwater, FL
Clinton
2019 Ford Mustang GT Convertable
I rely on Waze, good enough. Floridians report everything. 🤪
Waze and Radar detector here.... That said, I detected a cop in my area using Laser last night for the first time.
And he was on the Waze app too. So that would have saved me if I was going the other direction.
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
The gun reports an error until your jammer shuts off, that’s gonna be really suspicious if they’re able to clock every other car except one. I did research these things I know how they work, you have to slow down quick enough.
I considered buying one too a while ago, but the risk is not worth it. Most police are still using radar anyway.
Too bad no one has come up with a stealth kit for cars. Something that absorbs the signals or reflects them at oblique angles that won't return to the gun, sort of like how our stealth aircraft work. Anyway, does anyone know what Utah LEOs use?
Sariandan
The lowcountry of SC & GA
Kevin
2022 Mustang EcoBoost
In the videos I've seen of tests, it doesn't report anything. Just waits for the speed to pop up. And we're only talking about a few seconds. Nothing that the officer will even notice. Is it enough time to slow down? I guess that depends on how stupid you were being. :crackup: But, it can take a four point ticket down to a two point ticket.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
This is correct, the LIDAR gun just shows blank as if they missed their target. It doesn’t return a false code or error tipping the cop off to your equipment. RDD (radar detector detector) however will so unless your detector has RDD defeat the cop will know you’re running one unless their equipment doesn’t have that feature.
junits15
MA
Justin
2019 Mustang GT
You would need to coat your entire car for that to work. Including the glass.
Also there is no commercially available laser absorber material on the market that would work on a car, there are commercially available RF absorbers that you can buy right now, but even they don't work at any level that would be enough to defeat a radar. At least, nothing that you or I are allowed to buy would work...
This is an example of a microwave abosrber material: https://www.laird.com/products/microwave-absorbers/microwave-absorbing-foams/eccosorb-an
Some of these type of products are available as a paint-on product, but currently nobody makes anything like this for laser light. You could theoretically paint your car in RF absorber and be stealthy and less visible to radar, but I assure you that you'd be not too fond of the look lol.
Your best option for something like a laser would be some sort of diffuser. This is what some diffusers (real diffusers used in photonics labs) are like: https://www.edmundoptics.com/f/ground-glass-diffusers/12287/
These shown here ^ are the cheapest types of real diffusers you can buy, and you'll note that a half cm circle is $17 and made of ground glass. theoretically you could make a plate cover out of this stuff but the entire front of your car would remain exposed and they'd still get your speed. It will also block all visible light, so things like toll-plate readers wouldn't work, and you's risk getting pulled for an obstructed plate.
Laser jammers do actually work. Veil G5 claims to be real, but its just super fishy that the entire photonics industry has not created a paint on diffuser material and somehow Veil has.
Sariandan
Kevin
I was reading about the Veil stuff today, when looking at laser jammer reviews. Apparently, the previous generation stuff worked good. You coated your headlights, taillights, and license plates with it (the common areas they target with laser). But it caused paint to crack or something. Whatever this new stuff they make is, it's dark in color and looks like crap.
junits15
MA
Justin
2019 Mustang GT
Interesting, I wonder what’s in it. Not that they’ll ever tell us lol.
MROCGUY
AZ
buy a ton of microwaveable pizzas...wrap your car with the silver toasting sleeves facing outward.
now your mustang is a stealth mustang
GD~
Eastern Washington
'20 Mustang GT
I use Waze along with Uniden R3 mounted on a blend mount and mirror tap. R3 is an excellent performer at bargain prices. Previous vehicles all had a microtap from in cabin fuse box. Ran the power cable up through the pillar and under the headliner. Both power routing options work very well. Next detector will handsdown be a Valentine.
As mentioned before, check out Vortech radar website. All the information you could ever want can be found there. Guy also has a great youtube channel.
Oakley
Lee
2022 Mustang
laser jammers work like gangbusters. this one time mine went off as i was cruising behind this bimmer. flying. trooper SAILS around me to get the car in front... because when my jammer went off i slowed to near the limit and then switched it off.
i just rock a uniden these days cause i don't do much driving near dallas anymore.
DadzMach
2023 Mach 1
I have used the ones that come with the Escort 9500ci for years. Each time you would get hit with a laser the detector would go off. While this was happening the laser was being jammed. It would give you two seconds to slow down and then you had to push a button to temporarily turn the jammer off to prevent the LEO what was going on. This feature and the way it was designed to work never let me down in the 6 or 7 years I used it. They make a new version called the redlineCI which works flawlessly. You can either use it with a regular detector (redline 360) which doesn’t work nearly as well or go with the redline 360ci, which has worked every time for me. Highly recommend.
