mkcotton
I used a cradle... the alternator bolt and an open hole on the pass side... lifted one side at a time about 5-6". When I say lifted... I supported the motor with the cradle (both motor mounts removed)... I just never lifted both sides at the same time.Where did you attach the engine hoist from? I was about to lift from where the trans meets the motor until I seen the 2 lines that run across where I need to lift from. If I have to go buy an engine cradle from HF I will. I was hoping not to have to remove the steering shaft. I am about to remove the rest of the exhaust here in a bit & stop after the removal of the starter. I already have the car in the air. Thanks for your input.
