Rodpwnz
- Oct 14, 2019
- SF Bay Area
- Rod
- 2018 A10 PP1 401A GT
I was under the impression that camber plates were necessary as well to properly run 305 up front?Slighty bigger contact = slighty better grip vs same compound but smaller.
Not big science here.
There are many companies selling bigger wheels kit (APEX WHEELS i. E. ) staggered with no extra need to put on.
A common configuration is 285 front 305 rear. With 19x10 and 19x11 wheels.
Or
The squared setup has advantages and cons
Pros.
U can rotate easily wheels all around for better tire wearing (mostly for roadcourse usage)
Car will handle better. (305mm squared is common in mustang racing community
No issues for daily and great choice IF tracking is in the plans.
Cons
Tires cost more
In the front U need longer front studs with 25mm spacers.
Good luck!
I only casually track my car, so I went 10 inch square with 285/35r19 all around for rotation and to avoid 25mm spacers, extended studs and the camber plates. If 305 up fronts was a direct bolt on, then I would have gone 11 inch square for sure!
