Post Your Bead Porn
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Was that from hose spray rather than rain ?
It’s just I’ve never seen build up like that from rain, it normally runs off and leaves dry tracks if it’s natural :
@Need4SpeedMotors
Hi Junior,
Just checking which one is correct or if you did change, why, and did it help ?
These wheels are top of my list (when my current MPS4S’s are done) and I’m making sure I’ve got my new setup nailed before committing £’s :like:
WD :like:
Yes I did change the tire size, the 295/30 up front was a tiny bit too big on the 20" wheels. It could have worked but I did want to add too much camber. The 285/30 fits perfect on my car.
I wanted the rear tires to match the fronts so I ended up swapping to the 315/30 Michelins from the 315/35 Nittos.
WD Pro
United Kingdom
Lime GT
Thank you :like:
Could I run standard camber on your current sizes, or am I forced to run more ?
What camber (front and rear) does the red car run ?
I see from the other thread you have dropped it a little more - any rubbing issues ?
Cheers,
WD :like:
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Thank you :like:
Cheers,
WD :like:
Yes you would be fine with standard camber depending on how low the car is. The red car has no issues rubbing and is lowered at about 2 inch's, it is only running about -1.7 - 2.0 camber. I believe factory camber is about -1. If you stay around the 1 inch drop lowering springs you shouldn't have any issues get the camber back to factory spec with these Project 6GR wheels.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Wheels and paint coated with Adams Advanced Graphene Coating
mike3105
UK
2018 (pre-FL) manual GT
Gyeon Can Coat EVO topped with Gyeon Cure, topped with Armour Detail Supply Amplify as a drying aid.
I've just put Gyeon MOHS Evo on my car, and will top up with Cure on the next wash (maybe at the weekend). Hoping the results are similar to that!
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec
Last weekend bath. Coating unknown on my new to me Mach1 but it works pretty well.
skinnyb
Knoxville TN
Alex
mike3105
UK
Washed the car a week after the Gyeon Pure Evo (I think!) application. Here's a video and photo of the beads. Love how it is with fresh ceramic. Topped it up with Can Coat Evo and Cure. Not actually a fan of the application of either, too much buffing for my liking. I think it'd rather do a more frequent top coat of Wet Coat.
