Parking brake help!
Toybox06
Wichita,ks
Brian
2015 Mustang Ecoboost, 1967 Country Squire,
Since I bought the car used the EBrake has been a little out of adjustment, having to pull higher than expected to hold the car. But yesterday when I let it down it acted weird and now has a lot more tension when pulling up. Has anyone experienced this phenomenon? And what did you find to be the issue. Mine is a 2015 ecoboost base manual transmission.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Jack up the car and take a look. The parking brake adjustment is under the car in the axle/exhaust tunnel. Its a 10mm nut on a threaded rod. If it got stiff it could be hung up on something.
Skye
≈39N
"Skye" Mach1 N2144
Yes, visually inspect the parking brake cable; it's a somewhat simple mechanical design. A physical problem could be easy to detect.
While you're there, inspect the pads and compare with the front or another car.
Date/mileage of last brake job? Miles on car? Could be the brakes are just worn and it's time to replace the pads.
