Oil Plug Being Difficult on '19 GT
Sivi70980
Lacey, Washington
2019 Ruby Red GT PP1 M6
Well that sucks and why would they do that ?
This thread was freaking me out a little as I tightened up the oil plug a little tough ( but not to tough ) and if it was plastic I could of easily stripped it. And then I was thinking I’m an idiot that don’t know the difference between metal and plastic and maybe I should not work on the car anymore. And then I was thinking WOW they make plastic today that looks and feels like metal.
Crazy thoughts right :)
FWIW, I’m wrong a lot also :)
Hahah love the train of thought! They did it for heat dispersion and weight savings. Haven't heard of many people getting them cracked too easily. Does make me hesitant on lowering the car. It also allows for more engine noise as someone posted previously. I'm surprised aftermarket isn't making aluminum pans like crazy, I'd have one already.
My last car had a crush washer that needed to be replaced every oil change.
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
Actually thought people said that metal sheds heat better.
David Schmidt
North Carolina
David
2018 GT Premium MT82 PP1 401A
Not a chance. It's plastic AF and it cams into place, not threaded in the traditional sense. This is my 2018:
Rock&Roll
New York
2016 GT Stick- 2022 VW GTI Stick -2011 HD Fatboy
Thanks for that pic and that puts my mind at ease. So much plastic on modern cars Yowzer
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Just to be clear ... Does the new plastic drain pan have the same thread as before? The photo of the new drain plug looks more like a twist-lok than a normal thread. EDIT: NVM. Just saw post #64.
I'm due for my first change, and I was already expecting the Horizontal Old Faithful event, but I haven't decided if I want to try to reuse the original plastic plug, or buy aftermarket.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
It's not threaded in the normal sense, more of a twist-lock thing as you said.
  • Like
Reactions: GTP
ctandc72
VA
'19 GT 6 speed Base
Actually a composite plastic, like the oil pan is made of, is a lot stronger than people realize - not to mention lighter. There are quite a few high end engines that use a lot of composite pieces on their engines - they wouldn't do it just to save money - losing weight is the same as adding more power -just easier.
Sivi70980
Lacey, Washington
My plastic plug was replaced with a valve but the plug looks almost unused. I'm sure they can be reused a few times without issue. I thought I read they were single use items and someone confirmed it was in the manual on a different thread but I can't find where it says it anywhere now lol.
boB
boB
2019 GT PP1
Neither the '19 Owner's Manual nor the '19 Service Manual mention to replace the plug. The service manual actually shows to reinstall it after draining the oil. I like the Ronin plug but even if I installed a new Ford plug each time I changed the oil it wouldn't pay for itself for 20 years.
I do not like Ronin saying the Ford plug is a one-time use item without any way to back up the claim.
RaceHorseV8
Illinois
Ricky
2001 Cobra, 2004 Cobra, 2019 GT
I can't find it either, looking at capacities and scheduled maintenance sections. Ronin says two different things (one on their site, one on Amazon):
"With no maintenance required, you will never have to replace parts or service anything, unlike the stock plug, which requires replacement each oil change, so you'll save money in the long run."
vs.
"The OEM Ford Yellow Plastic Plug requires replacing the O-Ring each oil drain. The Ronin Factory drain requires no maintenance, so the overall cost over the life of the truck will be less expensive with the Ronin Factory Easy Oil Drain"
What a concept, a OEM oil drain valve! It would also have to be removable in case of failure but an OEM drain valve would be the shit. Alas, the bean counters would never approve spending a couple of extra bucks...
boB
boB
2019 GT PP1
On a lighter note, draining the oil reminded me of Summersville dam on the Gauley River (WV).
https://www.bing.com/videos/search?...425ACA407257D2575CEE425ACA407257&&FORM=VRDGAR
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
This Ronin plug was designed for the Ford F150. It just happens to be an identical design on the 18+ Mustang. Is there anything in the F150 owners or service manual that says it's one time use?
Strokerswild
Southern MN
Things With Wheels
The owner's manual for my '19 F-150 makes no such claim that I've been able to find....
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
If the service techs don't replace these plastic plugs after each use then Ronin is guilty of spreading false information and using fear to sell more drain plugs. But whatever, I didn't buy it because of the supposed single use plug. I bought it and paid dearly for the convenience of not turning my garage floor into an Exxon oil slick at every oil change.
Sivi70980
Lacey, Washington
Agree, the potential savings on new plugs every change was a bonus for me too. And now that I've used it, no matter what the brand is, my future vehicles that use oil will all have valves.
