Oil drain plug
Slicktricky
Tn
2021 Ford Mustang Mach1
Fixing to change oil and wondered if anyone has swapped the yellow plastic oil drain plug for a more durable one like the UPR or any other one? Pic for attn
pt's21
NOWHERE
I installed a UPR 3025-02 on my first oil change. On that oil change My drain pan/container ran over because it was receiving more oil than it could drain into its container. Plus, I really don't trust the plastic plugs. The UPR plug I installed allows for controlled release of oil from the pan.
In addition, I added a safety wire to the locking tab so the base cannot unscrew. The moving part of the plug screws in to drain. This leaves threads exposed. The 'screw in' to drain plug also doesn't lock closed very well, so I trimmed and bent an aluminum "clip" around the threads. Now the threads are protected and the plug cannot be screwed in without first removing the clip. The third photo, below, shows the clip, it also shows the protective boot on the plug when shipped.
1 old racer
Fontana CA
Will
that was a great idea. think I will have to perform this mod to mine. once again, great idea!
mrgooden
Richard
2019 GT
I used the one you pictured, noticed the locking tab would cut into the pan some. I put the OEM back in.
Richard
Atlas1
Everett, WA
I’m going to use a femco drain plug when I do my 1st oil change
LOL WUT
Illinois
19 GT
I have the Femco plug on mine, great quality and makes for mess free changes.
cheeser
Colorado
21 Mach 1, 4Runners and RAV4's
I purchased a Femco for my first oil change, and purchase a factory yellow one as backup.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
I bought the UPR, for my imaginary Mach. It looks like a quality piece.
scd603
Boston, MA
2017 GT350
Has anyone ever heard of the plastic one coming out???
KeyLime
Pleasanton, CA
Lenny
2021 GT/CS Convertible
No, but the locking tabs can break off. It was cheap to install on the assembly line and Ford can sell more down the road.
I run a Femco on my airplane...if that's any sort of vote of confidence.
kz
West Chester, OH
Mustangs & F150
This is really unfortunately nonsense. Yes, they could - like the entire car could fall apart. Millions of F150s are using this plug and they're fine. Very of their users are replacing theirs with some aftermarket contraptions.
I've had UPR one, dumped oil on course, back to plastic ones which are just fine.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Break off on removal? Sure, if you're being ridiculous. I could also see it after several years of heat cycles. But they're never going to just break off randomly while you're driving down the road. Personally I just replace the plastic one every so many changes so I have a fresh o-ring. I like stuff like this better than the old days, when lube monkeys will blow out your oil pan threads by falling asleep on the impact trigger.
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Sticking with OEM plug here. I had good experience with the one on my '17 F-150. However it also had to have the oil plan replaced three times (warped and leaked)! My '19 has the aluminum oil pan from when they switched back. Kinda suprised they switched the F-150 back to an aluminum oil pan and not the Mustang.
Millions of miles on the OEM plugs and few issues at least I've never seen one, but these specialty plugs while convenient make me uncomfortable without a large number of users and miles.
Designs may look good on paper but until proven in the real world you could have this happen:
(3) Ronin Oil Drain Plug | Page 12 | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
On my F-150 I kept a couple spare plugs as a precaution to replace every few changes. Plugs were cheap, but it was probably unnecessary.
