foghat
Given that the 13-14 made 420hp, you are going to have a hard time comparing dynos with a 15 and saying they are (or are not) putting the same amount down. 15bhp difference is probably like a 12ish whp difference.It is true that if you search for dyno results on an 11-14 and compare to dyno results on the S550, they seem to be putting about the same hp range to the rear tires. Not something you'd expect considering the published differences in output. Actually had a post on this you can read if you search a few months back. However, considering the extra 200pds or so the S550 carries, it would make sense that it's slightly slower if the real, RWHP is about the same.
We have seen stock '15s putting dynoing from 340-385whp (dynojet) range, so there you go, that 12whp diff. is easily eaten up in the dyno variability. Even the 11-12s could fall within this variability.
The only way to know for sure would be same day, same dyno for both cars.
OP: What is your DA? Mine is usually around a 5000 - shitty. That will kill your tire spinning ability pretty quickly.
