Noisy Ring & Pinion
RBINCA
Nor Cal
18 10r80 GT, 07 GT500 Vert
Have a 2018 Mustang GT A10 PP with Procharger P-1X running E85. Bottom side mods are; Driveshaft Shop carbon fiber 1 piecedrive shaft, Driveshaft Shop 1400 HP rated axles, front is lowered 1" using Ford Performance street lowering springs, OEM springsin back, Viking Warrior shocks in back set at 4 compression & 10 rebound, Steeda stop the hop package including rear lower control arm spherical bearings, Steeda jacking rails, 17x10.5 Bracket Racer wheels mounted with 305/45/17 M/T ET Street R tires. All of the above mods were installed at the same time with 1500 miles on the clock.
In stock trim I made nine 1/4 mile passes with no noise from ring and pinion. After installing modifications I didn't even get through the tuning process, Lund, before the noise started. The noise increased exponentially after making three passes at the track. I'm talking loud, like you can not carry a conversation with someone in the car.
Replaced ring & pinion, bearings, seals, etc. put 350 easy miles on the car with no noise. Made three passes at the track and the noise is back! It's hard not to think that one or more of the after market items are causing this. Really don't know the best place to start to isolate the issue. Has anyone experienced or know someone that has experienced something like this?
Any constructive ideas?
RBINCA
RBINCA
Nor Cal
tt
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
I my opinion, if you had the work done as described and the noise went away for a while it sounds like a bad install job on the new parts.
Have you checked the following:
1) Driveshaft installation
2) Rear wheel bearings (NOT diff)
Describe the noise - other than just saying it’s loud... is it metal to metal contact, squealing, rumble, etc?
Anthony 05 GT
Also, does the noise go away during deceleration or acceleration or is it constant?
RBINCA
RBINCA
Nor Cal
Sounds like the typical ring and pinion whine when the lash is out of adjustment. The noise is not constant, changes at different speeds and goes away during acceleration and deceleration. Pretty sure it's not a bearing because not constant and not making a grinding sound. Everyone I've taken for a ride to get their opinion thinks its a ring and pinion issue. Very frustrating, gut feeling is caused by drive shaft. Talked and sent photos to Driveshaft Shop and they say everything looks good.
2-tone
Cincinnati
15 mustang gt m6
Who did the work ? Did they get the pinion preload perfect ? What did the pattern look like when they set it up ? Is it just a kinda quiet whine at highway speeds , or is it loud and constant ?
RBINCA
RBINCA
Nor Cal
Ford dealership did the install.As far preload and pattern don't have a clue. Makes most noise at 50-55 least at 65-70. Whine loud and constant until accelerating or decelerating.
Anthony 05 GT
Take it back to them
If the Dealership did the work and there is an issue, take it back; get either the Shop Foreman or the Tech to go on a drive with you. When you go on the drive, go where you can take it up to highway speeds, have all radio/accessories off and be sure to point out the timing (speed/rpm) when the noise occurs.
Don’t just drop it off without you going for a drive with the Shop Foreman or Tech - because it may only result in a “NF” (no findings) if they can’t replicate it.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
My buddies car did this TWICE. Started howling bad after 4 runs at the drag strip. He put a brand new loaded 3.55 differential in. Quiet as a mouse for 1000 miles. Made 2 passes at the drag strip. On the way home, the brand new differential was HOWLING….. Why are they losing pre-load?
TnWHTMARE
Knoxville
2020 Mustang 5.0
Just out of curiosity, does the aluminum/auto vs iron/manual housings have any impact on this? There was a gentleman who has been professionally installing gears for most of his life that shared with me that, in his experience, the aluminum housings seem to experience more issues than the iron housings. I'm not sure what everyone's combo listed above is but Im just curious if there might be any connection. I know my 18 A10 gears chewed themselves up by 3K and I was mostly stock.
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
Does this differential use a crush sleeve for bearing pre-load?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
schmeky
David
Then I would venture to guess this is the variable. Under very high loads I could see it loosing the pre-load.
May have to come up with a machined spacer and steel shims to get the pre-load dialed in and stabilized.
I have set up bunch of GM 12 bolt rears in the past and am familiar with the crush sleeve set up.
