Ring and pinion install specs
phunk
United States
'15 GT-PP
Anyone have access to the specs? I can't find anything for the new 8.8
I need torque specs for ring gear bolts and bearing caps. Also need rotation resistance spec (measured just 2.5in lb on the original one).
phunk
United States
'15 GT-PP
I was able to get the fellows at Ford Racing to look it up.
2015 Mustang Rear Differential Specs:
Ring Gear Bolt Torque: 100 lb.ft (135 Nm). Use new bolts with factory thread locker.
Pinion Bearing Preload: 16-29 lb.in (1.8-3.3 Nm)
Ring Gear Backlash: 0.008-0.012 in (0.203-0.304mm)
