No fuel pressure Arcane stage 2
DevonTK
Vacaville
Devon
2019 mustang gt gen 5x whipple
So I have everything wired and plumbed for the arcane stage 2 fuel system and am not getting fuel pressure trying to start. Any ideas?
DevonTK
DevonTK
Vacaville
Devon
I saw my fuel level wires were wrong. This is what I have now
Magony15
Northern Illinois
2015 GTPP Base/Prem, 2009 Ram 1500
The terminals under the hat can get loose too.
DevonTK
DevonTK
Vacaville
Devon
LOL WUT
Illinois
19 GT
Does my wiring look alright?
Your wiring looks good. Black to B post, R to R post. Fuel level wires to fuel level post.
If you’re having issues, check your ground, they can be very finicky. I have mine grounded to the car seat anchor bolt. If that doesn’t resolve the issue, it may be that the post on the underside of the hat are loose. I have not experienced that but it’s my only assumption given that the wiring to the hat looks good.
DevonTK
DevonTK
Vacaville
Devon
Ok thanks. And the wires going to the fuse box are ok how they are?
DevonTK
DevonTK
Vacaville
Devon
Both wires on the box go to the upper red.
Alright, I will move that one over. I sanded the seat belt anchor and grounded both wires to it. I will also try to ground it to the other seat belt anchor I guess. If that doesn't work I will remove hat and check inside it I guess. I had the company assemble the hat for me.
DevonTK
DevonTK
Vacaville
Devon
Let me know if you need help. PM me we can schedule a FaceTime
Ok thank you. I will try those things when I get off work and if it still won't work I'll shoot you a pm.
DevonTK
DevonTK
Vacaville
Devon
@DevonTK any luck resolving this?
I have narrowed it down to the relay box on the fuel system harness. I'm getting power to the relays but nothing from the relays to the hat. Checked the relays and they are good. After work today I'm going to take apart the relay box and make sure everything is cramped right. If that doesn't work I'm thinking about deleting the relays to see if that let's power through.
SheepDog
Colorado
Dax
Did you assembly the fuel hat, or have Arcane do it?
I assume there must be fuses somewhere in the harness or under that black cover, maybe you popped one.
DevonTK
DevonTK
Vacaville
Devon
Arcane assembled it. I checked the fuses by the firewall and they are fine. Power just isn't getting past the relays to the wires that run to fuel hat.
DevonTK
DevonTK
Vacaville
Devon
Ok I'm getting power off the relays to the hat now, but still no fuel getting pumped to the rails should I just take the hat out and check their wiring?
