cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
but the water damage was already present during last 2 battery changes, I havnt washed in washing machine since before the previous battery change. Lol
whatever though.
Hey ................ At least it's COVID-19 free. :crackup:
Tomster
Beware of idiots
Tom
cactus_kid
Michael
'21 GT (see sig)
Once initialized, the "check for updates" will tell you that you have the current version. Gives time and date of latest upgrade.
Tomster
Beware of idiots
Tom
Not here, just tried again.
I guess it doesn't matter, unless another update comes along I suppose and the system thinks you are still running the old version......
Caballus
Over Yonder
GT350
I've never been able to confirm my update using the website, despite successfully installing the updates. Each time, to include the most recent update, I called the Sync helpline and they updated my file manually--may be an overseas thing, not sure. You may have to convince them that they are able to annotate your file manually, as some techs are not aware.
After calling in this most recent update I learned two things: 1) Ford is aware that there is a problem (at least some techs are) and are working to fix it; 2) It really isn't a necessary step. New updates do not rely on previous versions. So, even if the system thinks you're two or three updates behind, the newest file will still bring you up to date. As for being able to use your VIN to check whether you need an update, you can simply compare the version listed on your unit to the one listed on the website.
Opinion: Based on #2 above, uploading the post-update file to Ford/Sync probably provides useful data for them to sell.
Snoopy49
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Depending on the SYNC sytem you are using , Nav and No Nav, the files may be different. That why you need to enter the VIN, this assures you that you will get the correct download your cars needs.
torque124
Torque
MA
Shelby GT350R
Did anyone confirmed the update on Ford sync site by uploading the xml file (usb install)?
I get "Upload failed. Please try again later. " when I try to do it. I did find it in the SyncMyRide folder...
Also, installation was very quick for me, it said "installing" for a few minutes only... and then "you can remove the usb media, the system will be updated at next restart" or something.
Thanks
Caballus
Over Yonder
GT350
I agree when it comes to downloading the update. However, it is not necessary for checking to see if you need it. If you fall behind, you will automatically be directed to the most recent update for your vehicle. Therefore, falling behind on documenting your version does not have any significant impact.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
A minor update...
I'm sure the geeks here are aware of these gotchas but for everyone else, here's what I found when I tried to update on our '18 SD with nav. I decided to drive the truck rather than let it idle and while driving, I hit "Audio." Dumb. That killed the update and I got the "failed, try again or call this 800 number" message.
I did..total waste of time, don't bother, they are zero help. Checklist readers and even after twenty minutes of useless questions, the person said her system didn't recognize the INSTL_ERR14 code. Worthless.
Re-built the USB stick from the ZIP file and tried again. No joy, same failure message.
Elected to try a second 64gb stick, formatted it, and re-extracted the files. Stuck it in the truck and in about five seconds, "Update Complete." So, as Don mentioned earlier, the system does remember where it left off.
So, you don't have to be in Park, you can drive or not, just DON'T touch the display. And, if you get a failure and can't restart with the originally extracted stick, try a different one, that will probably work.
DJ_Stang
Chicago, IL
2019 Mustang GT
Dumb question: I have a '19 GT base with the small screen (not touchscreen).. Should I still get the Sync update, would it change anything ?
Warpath
Springfield, MO
2020 Ford GT500, 2021 Jeep Trackhawk
I haven't got a chance to install on the GT500 yet but did install the update via USB on my 2020 F250. Same version with NAV and had no problems.
Tomster
Beware of idiots
Tom
I have the update and I cant see any difference
cactus_kid
Michael
'21 GT (see sig)
@Tomster ........ Our cars are now slower. The extra weight of the data heave down load is the issue. :facepalm:
