New guy with some questions...
16Kobra
2019 GT350R
1. Im searching for a red outlined snake as well
Working on this for you as per our text last night, When I hear from them I will pass it on.
16Kobra
2019 GT350R
I know where to get the red snake and they have other colors as well like twister orange
I know where to get the red snake they also have other colors like twister orange for the cobra here is the link
https://www.bemarofilms.com/
As for your question on JlT or 1350 cold air I have a picture of both I just saw the 1350 yesterday I have the jlt I like the jlt due to the heat shield box the 1350 is sucking straight engine hot air which you lose power
You were supposed to tell me last night about the link...:headbang::headbang::headbang:
Tomster
Beware of idiots
Tom
So those were just stickers..... offly expensive ones at that.
16Kobra
2019 GT350R
Tomster
Beware of idiots
Tom
So, did I understand correctly, Tom..you would like to REPLACE the metal exterior snakes with some of these painted versions when/if someone makes one using the new snake? Or maybe just the one in front?
Yes, if someone would make ones like the 07-14 red accent ones, but for the 2020.
Here is an image of the 07-14 red accent snakes.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Honestly, Tom, I bet you could paint them yourself using the same idea Mark used with his lower heat exchanger.
If you took a piece of vinyl or wax paper and put a teaspoon of vegetable oil on it, spread it around evenly then, set the snake face down and rub it back and forth until the high side is coated.
Finally, with a rattle can of Rapid Red, you could hit it with a couple coats, let it dry, then wipe most if not all the paint off the bright side. Might have to rub it on some 600/1200 grit to get it all but I think it would work.
Tomster
Beware of idiots
Tom
Yes, I was thinking something like that. However since I don't have the car yet, I don't know the material I am dealing with. I'm assuming they are plastic/chrome and paint finish?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
They are plastic, with what appears to be chrome and paint, yes.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Belay my last, amigo..I don't think my idea will work.
To date, I hadn't looked at one closely until you brought it up so I went out and had a looksee. I had thought they were made from the chrome colored portion with the black being the accent. But now, I think it's the opposite and I'm not certain all the high spots are the same height, it's tough to tell. And if you had to abrate the top surface to remove paint, you'd almost certainly remove that shiny "chrome plating."
But yes, unfortunately, they're plastic or at least they sound like plastic when you tap 'em. Definitely not as nice as previous 500's.
Tomster
Beware of idiots
Tom
Maybe I can send them off to China to be hand painted. I haven't had much luck with Chinese stuff lately though.
