Need a break from the rasp.
SheepDog
Colorado
Dax
left the factory resonator and active exhaust cat back
Yep. There is no power to be gained with a catback anyway. The Coyote may be the worst sounding V8 ever made, so exhaust choices/modifications are critical. I hear Mustangs all the time that make me embarrassed for the owner.
LethalSteveG
South Florida
2018 Saleen Yellow Label
So, I currently have Stainless Power catless headers with a Corsa Extreme catback. Since I went catless in April, the rasp has gotten pretty bad. When I had cats, it was tolerable, but I need a long break from it. I saw Lethal Performance in the last few months released a resonated doubled H pipe with 2 MBRP resonators on it and I'm thinking that should help cut out some of the rasp, and give me a deeper sound overall. I could have 2 resonators welded in on my current exhaust, but after parts and labor it's probably pretty close to the price of the Lethal Double H Pipe.
https://www.lethalperformance.com/l...ipe-2015-2026-ford-mustang-gt-dark-horse.html
My only real concern is I may have to modify the H pipe. My current Corsa X had to have a few inches cut off each tube to connect to my headers when I had them installed 18 months ago.
Has anyone used this H pipe, and if so, what's your opinion on it?
The resonated H pipe will replace your X pipe no problem as it's all based on Corsa parts and uses the factory clamps.
Now, if you modified yours I cannot say anything on that but it's a direct swap on Corsa Catbacks using the OEM clamps
MontiCristo
Rob
ā€˜21 GT Premium PP
I may be the exception, but I like the way the coyote sounds. WOT it is a bit raspy, but regular driving with the Borla S-TYPE with an H-pipe configuration in either sport mode or track mode exhaust sounds fantastic. I regularly get asked what exhaust I have on the car.
Gen 6 Mach1
Arizona
Jer
2021 Mach1
Straight from the Professional , Can't get any better than that . Go for it Jpump
Reading all the posts answers , I think I'll stay Stock on my Mach1. IMO sounds great.
Outlaw
Pennsylvania
2017 Mustang GT 5.0 Performance Pack
I have a resonator/no mid pipe. From what I found it's the best way to reduce rasp. It's the thermal r&d catback full 3in with 3in cat deletes. If you want I can try to grab a video next week when I get my car back from paint. I might have an older video but it won't be the best quality. What will say is down low it's fucking awesome like deep like the old 4.6s but like all catless setups once you get to WOT it's going to be raspy. The coyote is a raspy motor. To remove as much as possible you Have to have a helmholtz setup like thermal, solo etc. mbrp is pretty raspy when you are on it I saw a guy with a 2018 and similar setup with mbrp and an h pipe and it was raspy as hell when he gave it throttle.
qwiknotch
Southern California
Damon
Kona Blue 2018 Mustang GT,2k GT Vert,
My car has mbrp long tubes with an mbrp high flow cat h pipe into a 12469 Magnaflow and mbrp Street Mufflers
Here's the cold start before the 12469 and after
Franky16
Hurricane ut
Justin
23 MACH 1
Same. I think the coyote sounds awesome. Especially with a good tune
Jpump
Jpump
Arizona
Jeremy
2019 Mustang GT Premium PP1(Need For Green)
Waiting on my bonus before I order it, should be a few weeks.
Jpump
Jpump
Arizona
Jeremy
Got it installed. Car sounds so much better. Noticeable decrease in volume and the rasp is nearly gone.
OldbutNew
S.E.Michigan
Greg
2019 Kona Blue GT 10R (Wife's car) 2018 Mustang GT Royal Crimson PP1 Manual
My '18 is bone stock with Active Exh and I think it sounds just fine! I am considering the Mach 1 upgrade that replaces the axle back and the lower rear fascia. If it makes it sounds like a Mach 1, I think that's good enough. Too many guys here that have spent $$ only to want to un-do it later. If it doesn't increase power, I don't exactly want to change the sound tone or make it louder. YMMV.
djcodeman
Austin, Tx
2015 GT roush SC
I added dual 16 inch resonators to the back section of the H pipe and it took away the rasp
Gen 6 Mach1
Arizona
Jer
2021 Mach1
ObN , Agreed šŸ‘, M1 Sounds great stock look at all the money I've saved . Money Market accounts are paying 4.3 % interest :)
Jpump
Jpump
Arizona
Jeremy
Only clip I have from a Dyno Night on Thursday with the new h-pipe installed.
RNM
2022 Mustang GT
This did not age well.
MontiCristo
Rob
ā€˜21 GT Premium PP
