Mystery icon light
Torched10
Torched10
Atlanta
Bob
Arthonon
California
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
A white warning? Usually white indicates just info and not necessarily a warning or error.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
I'm seeing two red "oilcan" icons and one amber one in that second link.
I'm pretty sure that the icons with the squiggly line under the can refer to oil level, while the one that does not is related to other oiling system conditions (like pressure?).
Norm
Torched10
Torched10
Atlanta
Bob
Norm
Here's my artist rendering
It was definit white
Hasn't shown up again
I think I've ruled out anything seriouslike oil etc,pressure normal.fulloil.radiatit is full.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Where on the dash were these icons showing up?
Bikeman315
Myrtle Beach, SC
Ira
Exactly.....
Dashboard lights appear in several colors, and each color relates to the seriousness of an issue. Blue, white, and green colored dashboard lights provide information. For example, you’ll see a blue headlamp light when engaging your high beams.
Yellow colored lights represent issues or statuses that you should take note of immediately. You’ve likely seen the yellow seatbelt light come on if you’re not buckled up. While this is an issue you can fix, other yellow lights require service. For example, a yellow battery icon means there’s an issue with your electrical system, and it’s best to get your battery and alternator tested by a professional.
Red warning lights are the most serious, and you should identify and deal with the issue as quickly as possible. Red lights indicate a current failure in a specific area which can cause serious problems.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Just above where the 3 gauges appear on screen
No idea then. You likely saw something that is not normally displayed or some display function glitch. As others have said, if it was white, that's info, not necessarily a warning or problem.
Mike Pfeifer
Wesley Chapel, FL
Couple of questions: sounds like you have the digital instrument cluster- do the mustangs display a freeze warning below a certain temp? Do some mustangs have a camera on the front that may be obstructed by weather conditions (fog, rain)? I have had customers (not mustang) see white icons for these conditions and ask what it means.
Also, it looks like you drew an upside down drop, which might actually be a pointer pointing down, like for climate settings. Did it show two of them like you drew? If you turn your climate knobs all the way down, does it show what you drew? I don’t have the digital cluster so I’m not familiar with the expanded functionality it may provide in the mustang.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
You might be on to something here. The only place I have ever seen the LO LO is when the climate is set to max AC (one for left side and right side).
Those upside down rain drops also look like GPS pins.
The mystery continues...
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Yeah, but climate control information is never displayed on the IPC.
I think the most plausible explanation is a temporary software glitch. It might be some kind of debugging information that's displayed when the unit goes into some engineering or testing mode. Which you shouldn't see in normal use but was temporarily triggered by some electronic glitch.
We must keep in mind that the IPC is not merely a display. It's a very powerful computer in its own right, which is capable of much more than just displaying engine revs and speed. Who knows how many layers of software there may be behind the surface...
