MY20 Bullitt Engine Rattle
MikeyBoy
United Kingdom
Michael
Mustang Bullitt MY20
I don’t know if this can be heard great on the video but the last week or so my new Bullitt seems to have started to make a blowing type air noise when accelerating, not the air intake noise, lift up the hood and there’s this rattling sound when pressing the gas and it gets to a certain RPM...will take it back to the dealer but is anyone able to suggest what it might be or if this is normal? If I put more revs on it goes away, sounds like something is loose in the engine bay maybe.
The other thing is the engine starts kicking off this loud tapping sound when idle, apply the gas a little then it goes, sometimes comes back..
johnscousin
Salisbury, NC
Jim
2017 LB Mustang GT PP
How's your oil pressure?
jc
MikeyBoy
MikeyBoy
United Kingdom
Michael
So the latest from the dealer is that Ford have come back and advised them to swap the left and right flaps in the intake manifold?
Presuming they’re referring to the swirl/tumble flaps in the GT350 intake manifold?
Had it for 2 months, 3.7K miles broken in properly and not ragged it. At what point when they’re talking about manifold and engine issues would you say hang on a sec...don’t fancy having a car that’s inherently faulty where I don’t know what damage has been caused to it by some mechanical defect, especially as it’s so new?
Thoughts welcome on this one as I’m a bit unsure on what to do with this other than let it play out and see what they come back with....
The “flaps” may be in reference to the IMRC plates. IMRC plate disfunction has been an issue since the introduction of the 1993 Lincoln 4.6 DOHC (which was then carried over into the 96+ Cobras).
Ford prob wants Tech to confirm if the IMRCs are faulty or not before proceeding with additional diagnosis.
The plates can prematurely fail and can be replaced. Some folks have deleted the plates using “IMRC deletes”. Some say it’s better without, others say that with deletion there’s low end torque loss. If the IMRCs are replaced with factory parts, they should last at least a good 50-60k+.
You can research “IMRC” on here or via google and gets lots more info if needed.
MikeyBoy
MikeyBoy
United Kingdom
Michael
Thank you for the reply, that’s really informative. Will have a look on the forums and online, much appreciated.
MikeyBoy
MikeyBoy
United Kingdom
Michael
Latest is they’ve placed and order for a new IMRC actuator/control unit...apparently it’s failed or not functioning normally, 4 days wait then will see what the situation is and if it’s resolved the issue.
That should fix the issue - definitely keep us updated and best of luck!!
MikeyBoy
MikeyBoy
United Kingdom
Michael
So waited almost a week for the part and the dealer has ordered the wrong part...apparently the part number is wrong in the UK parts system and told on Friday they’ve sent the actuator for the standard manifold....so another 4 days to a week wait for the correct part as they’re saying there are no GT350 manifold actuator parts in the UK....
In the meantime they’ve provided me with, what I was told at the time of getting the car would be like for like, a replacement for the Bullitt...a Ford Kuga....someone is taking the p***
At the same time I’ve got the dealer whinging that it’s costing them to fix the car and ignoring a better spec replacement for the hire car....
MikeyBoy
MikeyBoy
United Kingdom
Michael
Part arrived, issue still there. Told they’re ordering a new manifold now....another 1 week minimum wait.
