Moving from D to S, S to D while moving?
drumstick
Oklahoma
2018 GT
The tranny (a10) is made to handle this without any effects correct?
DoubleX
Illinois
'17 Ford Mustang GT
NO. Bad move!!
(Edit - I'm an idiot and thought this was from D to N and back)
steph93lx
Montreal area
2018 GT 301A A10, Modded N/A 1993 coupe 5.0L
No problem at all!!
You don't even have to push the button to change from D to S & S to D that's alone tell you it's ok.
I am doing it regularly!
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
There is no negative effects. I do it all the time.
drumstick
Oklahoma
2018 GT
Thanks for the quick replies- what about under WOT from S to D to turn it from paddles (keeping MPH) to auto (D)
michail71
2018 GT 401a A10
That seems like an unusual time to make the choice to switch.
But at wot the trans will be keeping the RPM at max power. It probably isn't needed as you can only maintain it for several seconds.
ahl395
Allan
That is fine. Just tells the computer it can take over shifting when it wants to.
69mach1-395
central nm, usa
2016 RR GT/CS
I get some jerkiness sometimes in certain conditions on my A6, but I'm often switch between S & D.
ihc95
2018 GTPP A10 401A
No problem at all!!
That's interesting. My car requires me to press down on the button to go from D to S and back. :shrug:
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
I have no knowledge on this subject, but I'd assume it is okay to switch from D to S to D while moving, but completely off the throttle.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
i believe that used to be the roll racing method, put in S to hold the gear, then go WOT and put back into D so the computer can shift.. not sure if that will work for the short gears of the 10 speed
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
I have no issues leaving my foot on the gas. Your not putting it into reverse. All you are doing is telling the computer to change the throttle response and shift strategy. Doesn't hurt it at all.
DickR
Raleigh
FYI you can go from manual in S back to automatic in S by holding the upshift paddle for a couple of seconds. Also if you ever have long downgrades where you would like some engine braking but prefer to stay in D you can paddle downshift in D and it will hold the lower gear as long as you don't touch the gas pedal.
ivantwilliams
Georgia, USA
2018 Mustang GT Premium with Performance Package
It is always nice to come across a thread, where you wanted to ask a question, but didn't.
Thanks for posting, and thanks for the responses, too.
PS: What is WOT?
Grimace427
NoVA
2011 Mustang 5.0
PS: What is WOT?
Wide Open Throttle
