AngelDeath
- May 5, 2016
- CH, New Jersey
- Mike
- '20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
You are correct, which is why I mentioned to see if the left side can be plugged into the right side (or vice versa, the right to the left) and see if the same issue occurs, if it does then it would answer the pending question.Okay check the strip same possibility. The hyperflash indicates the circuit is incomplete. Usually it's the bulb or in this case the led.
