Modifying As-Built Data Guide
jperls
Thousand Oaks
Jason
2015 Magnetic Metallic V6, 1970 mustang convertible
That's a great question. If you find the answer, please let me know and I'll update the spreadsheet with the correct/updated info.
Interesting to see your 0=not on list of what it controls...what setup/options do you have on your car currently/from the factory?
I am a base car...so I have manual climate controls "single zone" with "manual buttons"...nothing comes up on my screen when I make changes to my climate...so this should be interesting. [MENTION=25607]Spart[/MENTION] I think is going to give this a go in his GT.
My guess is that this has to do with my ford touch if anything and not not Sync 3. We will have to see. :)
EastTNMustang
Knoxville, TN
2017 Roush Stage 3
Ok...that's making more sense. The MFT is definitely different codes than the Sync 3. Let me know what you discover that works.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
Got a USB obd finally. I got mycolor gauges as well. My question is if I copy my original cluster as built files and whatever else I can and program the new my color cluster with my old inputs would it work? Also anyone know how to turn mycolor back on as in what the value is. Reason I'm asking is that the new cluster has collision warning on, blis, adaptive cruise control, and sensing alarm, basically all the premium stuff. I am thinking it would be easier to flash the whole cluster then re-add mycolor and be done with it. Any help is much appreciated.
Falk03
Munich, Germany
Falk
Mustang Convertible
I think it is easier and safer to disable all the features you do not need. Do you know the changes you need to do?
Otherwise I could look them up.
Kahboom
Kahboom
Cathedral City, CA
I need to disable Blis, need to disable adaptive cruise control, need to disable Collision warning, need to disable the event Security package as I only have the regular standard alarm, then I need to enable the drive modes as I have installed the premium benzil and never activated it but I think I found that feature on another form I plan on installing these gauges tomorrow which will probably be actually later tonight on Saturday and try to figure all this out shouldn't be too bad since I'm on vacation this week but any help would be awesome. Also if it makes any difference I have a performance pack GT thanks
Falk03
Munich, Germany
Falk
Mustang Convertible
Here are the some changes for a start.
1)
CTA disabled
720-01-01 xxxx xxxx *xxx 7 --> 6
2)
BLIS disabled
720-03-01 *xxx xxxx 6 --> 2
3)
Collision Avoidance...
720-04-01 *xxx xxxx xxxx E --> 0
720-01-02 xxxx *xxx 5 --> 1
4)
ACC
720-01-01 x*xx xxxx xxxx F --> C
5)
Alarm
720-02-02 0xxx xxxx Maybe ? --> 4
Hope this helps a bit.
Kahboom
Kahboom
Cathedral City, CA
Thanks will try this afternoon.
Spart
Midwest
17 GT350
The line of code referenced in the spreadsheet is this:
7D0-01-01 : xxxx xxxx x?xx
- changing the value with the question mark will only disable the soft climate buttons for the heated seats and steering wheel.
What I am curious about is this coding:
7D0-01-01 : xxxx xxx? xxxx
According to the F150 spreadsheet, changing the value at this locaiton tells the APIM what type of climate system you have and you have HD radio as well (Climate Front Zone & HD Radio: 3=Dual Zone & HD radio avail, 2=Dual Zone & HD radio not avail, 7=Single Zone & HD radio avail, 6=Single Zone & HD radio not avail).
On my as built data sheet, I have the following code: 7D0-01-01: 0C67 9800 04E8
So to truly disable the dual climate zone soft button and settings and not have a code thrown as has been talk about earlier, I would have to change the 0 to a 6. The question is, would this affect the FCIM controls and how they function (meaning only one climate control wheel would work or both could still adjust the temp in the car).
Thanks
Okay, here's something very important I want to point out:
7D0-01-01 0C67 9800 04E8 is as-built for a BASE 4" APIM.
Do not try to apply base APIM as-built do your Sync 3 APIM! You're asking for a whole bunch of problems.
MFT and Sync 3 APIM's, while they share the same 7D0 prefix as a base APIM, have wayyyy more as-built addresses than the base 4" APIMs.
Spart
Midwest
17 GT350
I gave this a shot, and setting it to six just got rid of any climate options in Sync 3.
I wouldn't stress about removing the passenger side controls. They don't hurt anything, they just don't do anything. Can be useful if you have a passenger and you want her to think she has control of the temperature, too. ;)
Spart
Midwest
17 GT350
Also interested in a soft touch button for the rear camera:
D0-02-02 xxxx x*xx xxxx Camera Toggle Button (CTB) & Trailer Reverse Guidance (TRG) & CHMSL Camera & Aux Camera
54
0=CTB hard & TRG disabled & CHMSL disabled & Aux Camera disabled
8=CTB soft & TRG disabled & CHMSL disabled & Aux Camera disabled
55
1=CTB hard & TRG disabled & CHMSL disabled & Aux Camera enabled 9=CTB soft & TRG disabled & CHMSL disabled & Aux Camera enabled
56
2=CTB hard & TRG disabled & CHMSL enabled & Aux Camera disabled A=CTB soft & TRG disabled & CHMSL enabled & Aux Camera disabled
57
3=CTB hard & TRG disabled & CHMSL enabled & Aux Camera enabled B=CTB soft & TRG disabled & CHMSL enabled & Aux Camera enabled
58
4=CTB hard & TRG enabled & CHMSL disabled & Aux Camera disabled C=CTB soft & TRG enabled & CHMSL disabled & Aux Camera disabled
59
5=CTB hard & TRG enabled & CHMSL disabled & Aux Camera enabled D=CTB soft & TRG enabled & CHMSL disabled & Aux Camera enabled
60
6=CTB hard & TRG enabled & CHMSL enabled & Aux Camera disabled E=CTB soft & TRG enabled & CHMSL disabled & Aux Camera disabled
61
7=CTB hard & TRG enabled & CHMSL enabled & Aux Camera enabled F=CTB soft & TRG enabled & CHMSL enabled & Aux Camera enabled
Tried setting this to 8 and nothing happened. :shrug:
Spart
Midwest
17 GT350
Here you go boys... let me know. This one was fun to figure out. I was previously restricted to low beams only and any other change would give an invalid configuration error in FORScan. Well this changes that...
Allow All Alternate DRL Options (Restrictions Removed - No Invalid Configuration Errors):
BdyCM (As-Built Modifications)
Allow All DRL Choices:
726-45-01: xxxx 7Fxx xxxx
Enabled DRL Selection:
726-50-01: XXxx
XX:
01 = Disabled / Parking Lights Only (See change below)
02 = Low Beams
04 = Front Fog Lamps
08 = Front Turn Lamps
10 = Dedicated DRL Lights (LED Light Bars/Strips) - Enables BCM DRL Outputs - C2280F Pins 36 (Right) and 40 (Left)
20 = High Beams
40 = Low Beams and Dedicated DRL Lights
Optional: Enable DRL Parking Lights:
Can be combined with other DRL options above
726-26-02: x1xx xxxx xxxx
Optional: Disable DRL Switchback w/Turn Signal:
726-26-02: xxx0 xxxx xxxx
On/Off for these is controlled from the Instrument Cluster DRL Control.
I know many of you change wiring and such to accomplish some of these which can be now changed in seconds... so enjoy!
Anyone actually get this working on a Mustang?
I tried it today, and while I have the DRL on/off option in the IPC now, my fog lights aren't coming on as DRLs. And yes, I released the parking brake, car is a manual. They come on normally when I turn the headlights on of course so they're not burnt out or anything.
Has anyone run across the coding for the following:
1) Increasing fan speed of the TED’s in the seats for cooling/heating? This would be for the leather seats that have the cooling and heating capabilities. I had come across a TSB for the Lincoln’s where there was a blurb to modify the settings, so I’m wondering if the same can be done for the 2015-2017’s where folks are experiencing lack of cooling/heating.
2) Turn off the auto dash cluster illumination change. The little sensor on top center of dash - once it detects daylight, it will change the dash illumination from your My Color or set color illumination over to white. Can this be fixed so that whatever color is chosen, the illumination won’t flip to white in the daylight?
3) 6R80 or 10R80 specific (with analog dash cluster): Is there any way to display the trans gear # all the time and not just when the Driver is manually changing the gears?
Thx
buzz-dee
Germany
15 GT Premium PP
It's working on my ‘15 manual gt.
You need to release the parking brake AND light switch has to be set to AUTO.
If one of the conditions is not met, the fogs won’t come on.
Fray_s550
California
Ford Mustang S550 V6
Is the ELM327 incapable of reading IPC and ABS modules? These options are not appearing when I connect
Spart
Midwest
17 GT350
Not all ELM327 adapters are created equally, virtually all of them are shitty knock-offs.
I recommend people get the ODBLink MX Bluetooth for this reason.
