Modifying As-Built Data Guide
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Please let us know and I’ll add it to our spreadsheet.
I can confirm this works :thumbsup:
Using Forscan to enable cornering light with turn signal and at low speeds with just the steering wheel
BCM 726-26-01 change to xxxx x1xx xxxx
Chappers
Greg
In forscan in the predetermined options you can toggle there is a slot for digital speedo but when I enabled it, it said it was an invalid configuration :confused:
EastTNMustang
Knoxville, TN
2017 Roush Stage 3
Can you explain what this does? Thanks, I’ll add it to our FORSCAN spreadsheet once I understand better what this setting affects.
Chappers
Greg
Yeah sure at night with your dipped lights on, when your below a certain speed if your turning the wheel left or right the fog lights turn on in that direction I. E. Left fog when turning the wheel left.
Or when indicating the fog light comes on I. E. right indication with right fog
These are fairly common on EU cars and referred to as cornering lights they light up the road ahead your turning into. Some vehicles have a dedicated light for this others use the fog lights.
Hope this helps. I'll try and get a video recorded to demonstrate
EastTNMustang
Knoxville, TN
2017 Roush Stage 3
Nice...I’ll have to see if this works on my US-spec car too.
Thanks
Chappers
Greg
Thanks
Video Demo here, you'll have to excuse the apparent flickering just the gopro picking up on the refresh rate of the LEDs but to the human eye it fades in and fades out.
just realised i've got my left and rights the wrong way round hahahaha :lol::lol::lol:
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
Is the ELM327 incapable of reading IPC and ABS modules? These options are not appearing when I connect
Does your ELM have a switch? If not its only reading the HS-CAN 1 bus. You need the switch to enable reading the HS-CAN 2, 3, and MS-CAN. IPC and ABS are on HS-CAN 2
BULL1TT
culpeper, va
2015 mustang GT, 2001 Bullitt
I'm having a problem getting forscan to change anything. I have made changes in the past and it worked great. I tried today and every time I try to access a module it says voltage too low. Voltage must be 11.6 and yours is 11.5. The voltage on my Lund ngauge shows 12.3 and I have checked it with a multimeter and it shows 12.3. Any ideas what is going on?
EastTNMustang
Knoxville, TN
2017 Roush Stage 3
I had something similar...I had to put a charger on my battery as I did the programming...sitting over the winter had drained my battery a tad. Once I had the charger on for 30 minutes, everything programmed as normal.
Spart
Midwest
17 GT350
The voltage always differs between the car's built-in gauge and the one on my radar detector. :shrug:
I almost always hook up a battery maintainer when I'm playing around with FORScan.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
I started the car and made changes using forscan. Didn't have any adverse effects.
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
Make sure you're running the latest version. It seems to be more lenient on voltage then it used to be. Just start the car for a minute then try again. Otherwise put the battery on a charger while making modifications.
Kahboom
Kahboom
Cathedral City, CA
Redline 720-04-02 XXXX **XX 0X = 6500 RPM 12 to 17 = 7400 RPM These seem to be the only two options. I do not know what else this sets.
After looking at the 18 redline not sure how this would translate to the 15-17. Instead of 0X it is 00 for 6500 so not sure if you can set it to 7400 rpm for mycolor on 15-17 cars.
Fray_s550
California
Ford Mustang S550 V6
It has a switch but when I switch it the other way it gives me an error message when I try to connect
chain
PA
2017 Race Red GT
Just watched some YouTube videos and feel a little more comfortable with the thought of messing with this stuff. Ordered a connector thingy and I'll be digging around in there this weekend. =)
First mission, disable stupid double honk when exiting my car.
