Maximum tire size for squared set up
WillsGTCS2017
Knoxville Tennessee
Will
2017 GT California Special
I was wondering what is the largest diameter and width tire fitment for a stock 2017 GT California Special Convertable? What rim width and what offset should be used? I want to keep the tire just inside the top of the fender well. I like the bold stance look. Thanks in advance of any information or tips.
Zelek
Hutto, TX
2021 Mustang Mach 1
I'm running 285/35 squared on 19X10's. Might be able to pull off 295's but it could be close up front.
Brian@BMVK
Illinois
2015 GT - Sold
On your stock wheels? 255/40R19 is widest recommended tire.
11" wide wheels and 305/30R19 tires can fit on all four corners, but requires extended studs and slip-on spacers on the front to make it fit. That is considered a track setup only, not recommended for daily use. A typical setup is 19x10 +35 all around with 285/35R19 tires.
Brian@BMVK
Illinois
2015 GT - Sold
285 35 19s will require atleast 1" spacer on the front, even 275 40 19's require atleast 1" spacer on the front, atleast with 2018's, and that is without magnaride. Not sure about magnaride setups.
No, not with a proper offset wheel (19x10 +35). That's just not true.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
True I was thinking OEM rear pp1 wheels sorry about that. Wondering why the 305's would require spacers even with proper offset?
305s only require spacers if you want to run square wheels. You can run 305s on both corners w/o spacers if you run different and specific offsets front and rear. PP2 does this for example, and at least one aftermarket manufacturer offers wheel offsets suitable for fitting no-spacer 11"s with 305s.
WillsGTCS2017
Knoxville Tennessee
Will
Thanks for all the info, there's a lot more to this than I realized. Not sure what Pp1 or Pp2 mean?
NightmareMoon
Performance Pack 1 or Performance Pack 2 factory option packages. Not to be confused with PP1/PP2/PP3 meaning the dealer installed “power pack” engine mods.
PP1 cars get wider wheels (9” fronts and 9.5” rears with 255/275 MP4S tires, torsen diff with 3.73 gears, and different springs, swaybars (and other bits). PP2 equipped cars get 10.5” front wheels and 11” rear wheels from the factory with 305 Sport Cup 2 tires on both ends, and additional different springs and other bits and bobs.
WillsGTCS2017
Knoxville Tennessee
Will
Thanks for that, im learning the lingo
