Squared or Staggered set up
turtleboy
Palm Springs, CA
15 EB
I'm be looking for new wheels and tires when I get my car. I know stock is a square set up, but would a staggered setup mess up with the handling? I'll be taking a few drag strip runs, but want to mainly run autocross.
dgc333
MA
15 Mustang Ecoboost Premium
Performance pack is square on the Ecoboost.
ecolulz
Arizona
2015 Ecostang, magnetic, base, PP, Recaros
Come on guys, let's be adults and assume that he's getting a car with a sqaure setup, like he said...
Turtleboy, I'd drive it first and see what you think. A staggered setup CAN make an oversteery setup more neutral, or an understeery setup understeer more. Drive it for a while and see how you'd like to change the car's behavior.
For autocross, I really doubt you'd want staggered. Cram as much tire as you can under the front, and match it on the rear, likely a 285 on a 10" wheel. That's my plan.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Here are the 2 benefits and non benefits.
if you run a square setup you can rotate the wheels all around and run the same tire all around, in a sense it will be cost effective and manageable on pricing.
If you a run a staggered setup for wheels you can technically run a wider tire in the rear since the rim is wider it provides a wider contact patch and thus better traction depending on the tire, downside is you will not be able to rotate all around and the cost can be a bit more expensive.
Since your looking to drag I def recommend a staggered setup with wide tire and wheel for the rear.
Blk2015GT
2015 GT
i had staggered on my S197 daily driver and won't do it again. Not being able to rotate made life a pain.
Plus on these S550s you can easily run 10 inch wheels with 275s as a square setup. That's a decently wide wheel/tire.
For drag just buy some special use back drag slicks on wider/smaller diameter wheels, and run square daily driving.
tmcbigblue
ky
bmw 325i
How big of a difference would it make having a 10in vs a 11in tire in the rear traction wise. Is the difference a lot?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Not a big difference to be honest, it would be awesome to have a 11" rear though
Grimace427
NoVA
2011 Mustang 5.0
+1. Big wide street tires are about as useless on the drag strip as somewhat narrower street tires. Both will spin. A smaller set of drag tires will out perform even the widest street tires at the strip and can be a hell of a lot cheaper.
Rypkr937
Beaver Pa
'15 Coyote Premium
Blk2015GT
2015 GT
Go through tires a lot faster since they can't be rotated to wear perfectly even. And big tires aren't cheap. $250-400 for a 275 tire, not including mounting and balance.
