Jewishthunder
There is a slight increase of what I would call ambient noise. Not like a squeeking, or clunking. When you're on a hard road, harsh condition, it's reflected a bit more in the cabin. I'd say if I had to rate the increase in comparison to other cars I've done these sorts of upgrades, I'd rate it a 2/10 increase. It's really minimal but it's there.Any increase in other NVH?
I did it on a lift, with the subframe let down a bit. You have to drop it down a little to get the fronts out/in. The rear mounts are a breeze. Whole thing took us about an hour.That's good to hear. Are these was simple to install as they look? Does the weight of the car need to be off the suspension or can it be left on the ground?
You'd probably fight quite a bit to make it work on the ground. Edit: (I don't know that it would even be possible actually)
