Lund flex fuel timing issue on Dyno. Your thoughts?
Patrick Dietrich
Fort Wayne In
Patrick
2016 Gt350 tech package
Sae stock-469
Flex tune-486
Here's the wierd thing. Datalogs on the road were perfect. Timing 31 degrees.
But when I ran datalogs on the Dyno runs , the car would only allow 26degrees
Lund says the 6 degrees would amount to a good 15hp. Just put a catch can on today. Lund thinks more than likely that oil getting in intake is causing a lower octane reading causing the car to hold timing back. But again, datalogs were fine on the road. Is it possible that on the Dyno when all the problems develop like traction control, brake light comes on and who knows what other things go on could cause the car to hold back on timing? The other thing the car did was not allow any throttle for a min or so . We held the peddle down and the engine did nothing?? Tried to put it in dragrace mode and it would not allow it. Maybe there's a trick to this car on a Dyno I know nothing about. Any help or thoughts is appreciated.
DocWalt
SE PA
GT350
Did you completely disable advancetrac (put it in dragrace or whatever and then hold the ESC/TCS button up for 7 seconds)? I am not at all familiar with dyno'ing a GT350, but I know on other cars you have to disable the stability control or it does weird stuff.
Patrick Dietrich
Fort Wayne In
Patrick
Well maybe this is the problem. I turned traction control off with the toggle but still had lights lit up .
Patrick Dietrich
Fort Wayne In
Patrick
So a friend just informed me I must hold the traction control button for 10secs to shut everything off or the car will pull timing ☹
Wish I would have known
65sohc
Fresno, CA
2016 GT350
Were you running e85?
65sohc
Fresno, CA
2016 GT350
I remember when I had my Boss dynoed at AED Shaun mentioned something about the front wheels not turning while on the dyno that caused an issue.
65sohc
Fresno, CA
2016 GT350
What octane did you use for baseline?
Patrick Dietrich
Fort Wayne In
Patrick
Yes. His tune for my friends gt500 shut all this crap off
Ninjak
Posting from the Shadows
The Shadows
David
2024 Dark Horse Supercharged 2024 Bronco Raptor 1968 GTA Mustang
When I had my GT500 I always turned off the nannies for the dyno pulls. Good to know its no different on the 350. I have a appointment with Power by the Hour for the 12th of October, so I will try to get as much posted as I can. Should be interesting.
Patrick Dietrich
Fort Wayne In
Patrick
Let me know how you do .
Ninjak
The Shadows
David
Roger that. Headers are here and Jon JR wants me to do some data logs on the 93 tune he sent me so he can prepare the flex and the ghost cam tunes. I seriously doubt if I use the ghost cam tune, but looking forward to the flex one.
Will have to say that I need to stop watching these turbo install vids though...
65sohc
Fresno, CA
2016 GT350
FYI for California residents: According to a petroleum distributor my son plays hockey with, next month the price of gasoline increases by 18 cents/gal. thanks to Brown's latest tax. HOWEVER, e85 will be exempt, all the more reason to run a flex tune.
