Loud noise from engine coyote gen3
m3incorp
Georgia/Colorado
James
m3incorp
Georgia/Colorado
James
That's when many report they began hearing the famous tick. Mine definitely became a little louder after my second oil change after purchasing the car new, but not that loud.
Yup right after an oil change got the noise
19BULLITTwhipple
Ramzi
Bullitt 2019
That’s cold start. When it warms up it’s not as loud. But the video I posted is dead cold.
It’s a noisy valve train issue on the gen 3 cars from what I gathered. It’s in the heads if you listen closely. It’s not the bottom end
NGOT8R
Adrian
2019 Bullitt
Take a look at this video. The repairman got lucky and was able to fix it without removing the timing cover.
MRASPHALTO1
Dominican Republic
Lawrence
Mustang GT 2020
I had seen this video a while ago, and after watching it, my belief that it might be a problem with the camshaft and lifters increased a little more since the sound is similar.
MRASPHALTO1
Dominican Republic
Lawrence
Mustang GT 2020
Hi everyone, I have an update. After trying a thicker oil (5w40), applying two flushes, and using Mollygen with Ceratec, the noise persisted (though a bit quieter).
Since I ran out of options, I decided to take the car to a mechanic recommended by several people who own Mustangs. To make a long story short, the mechanic found three bad lifters, a pulley slider that wasn't turning, and a cracked crankshaft pinion (I was lucky that no teeth broke and that the part held until I got to the mechanic).
Here's how it sounded before when cold versus how it sounded today when starting from cold. I still can't identify the knocking sound, but I don't know if it's the fuel pump, which is quite noisy, the camshaft timing components, or something else.
Old:
Today:
NGOT8R
Adrian
2019 Bullitt
Glad to hear your mechanic for you squared away! It’s nice and quiet now.
MRASPHALTO1
Dominican Republic
Lawrence
Mustang GT 2020
For now I need to save up since I spent quite a bit on this small repair, even so I will continue investigating the metallic noise that can be heard in the video, I still believe that sound is not normal in an engine.
NGOT8R
Adrian
2019 Bullitt
That was a major repair IMO. Pulling the valve covers, pulleys and dropping the oil pan to remove the timing cover was a lot of work. The remaining noise sounds like it could be injectors to me.
Do you still have the foam pieces over your fuel rails and the foam block that goes in the intake valley? Those are designed to help mask some of the noise.
