Loud constant ticking from engine
jp1234
USA, GA
joe
2015 mustang gt premium
Remove the vapor line from the Purge valve and see if there is fuel or oil in it. Also inspect the electrical connector for corrosion, bent or pushed out pins.
Alright I'll check that tomorrow when I get off work and I'll post an update then
jp1234
USA, GA
joe
Hey I checked the old purge valve for gunk in it, all I found was a little bit of maybe oil in the side where the I ring sits, the other parts were clean and no bent pins
SheepDog
Colorado
Dax
How about the electrical connector? Look at the tiny tabs inside the connector and make sure they arent pushed out, corroded, damaged
DougS550
Fishers, Indiana
Doug
. Here's a video of the ticking
I would use a mechanics stethoscope and narrow the noise down. Kinda sounds like injectors.
SheepDog
Colorado
Dax
See Post #8. He pulled the plug on the valve and it stopped ticking
Zrussian13
Phoenix
My car sounded like that a while back. I thought the engine was fucked so i babies it for a few days and everything felt fine so I finally said screw it let's open her up and see if it blows. After a few hard pulls the noise disappeared. Not saying this will work for you but the coyote seems to make a lot of jacked up noises. Since then when ever I hear a new one I just beat on it harder and wait for it to disappear.
jp1234
USA, GA
joe
I'll give that a look when I get off work and let you know
