Lightweight CF Drive Shaft options Tremec!
RandomTask
DFW
Aaron
2021 Mach 1, 2020 F350 DRW Platinum
Anyone running lightweight CF DS from the Drive shaft Shop or QA1 on their 6 speed Tremec? Anyone have real world experience before I hit the button. Tremec 6 speed Mach 1 users only.
https://www.beefcakeracing.com/dss-fdsh60-c/
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
I have the DSS one piece aluminum on my 2016 MT82, it's been great. No nvh, the car feels quicker with the rotational weight savings . Can't go wrong with a lighter driveshaft.
RMoeslein
Pittsburgh
Rich
2022 Mustang Mach 1, 2020 f250 lariat Tremor
I put a new DSS aluminum driveshaft on my 2022 M1 last summer. Its coming off in the spring and getting replaced with a QA1 carbon fiber shaft. The DSS shaft is terrible. not balanced, shakes from 50-60mph. DSS quality has gone down the drain. I bought axles from them also that both leaked grease within 100 miles of install. Had to take them off also. So much wasted money. I will never buy anything from them again.
John S
Novi, Michigan
2022 Mach 1 HP
Good luck. GT500 uses CV joints at both ends but aftermarket ones use the conventional approach with only one. NVH on non GT500 is a hit or miss and it more of a axle/transmission system issue that the two-piece driveshaft design does a great job isolating. (The 10R80 application center support is especially compliant and sloppy for a reason.) I had vibration issues I couldn't resolve on a QA1 CF driveshaft on my son's 2022 GT w/10R80. The driveshaft was SFI approved and it had outstanding quality but it just didn't work out for daily driver use. Hopefully, your application is trouble-free.
