Noisy Tremec
RocketRod
Sydney
Rod
2021 Mach 1 6spd
Hey guys. I have a 2021 Mach 1 with the Tremec 6 speed. There is a noise like a cat purring very loudly coming from the back of the transmission. Can only be heard when windows up and cruising. Does not match engine RPM or input shaft RPM as it stays constant when (for example) traveling at 60 kph clutch in and engine idling. And normally when the car warms up, so does not do it when cold.
SheepDog
Colorado
Dax
You sure it isn't a wheel bearing?
RocketRod
Sydney
Rod
2021 Mach 1 6spd
Never heard a bearing sound like this, but I will check it out, and for that matter, I should sheck the diff bearing. Thanks.
AZ_Ryan
Arizona
2015 GT Premium
Maybe post a video of the noise. Sounds strange the way its described.
RocketRod
Sydney
Rod
2021 Mach 1 6spd
Hasn't rubbed off on me yet.
Skye
≈39N
"Skye" Mach1 N2144
