Keyless entry not working on passenger side
Rod27
St. Louis, Missouri
2018 Ford Mustang GT
Hello, I have a 2018 GT 10 Speed, and yesterday I noticed my key-less entry is not working on the passenger side door. The crazy thing is I can get it to work probably 1 time a day, I tried again today, but it doesn't recognize either of my key fobs. My driver door and trunk opens with no problem using key-less entry. Do anyone have an idea of what is going on here?
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Did you try pressing the button twice?
There is an ICP option to unlock "only driver door" or "all doors". In '16 that option could be toggled by holding both lock and unlock for a few seconds.
Rod27
St. Louis, Missouri
I'm talking about not using the key at all, like you can walk to the car with your key in your pocket and open a door. The passenger door is not operating correctly.
bdm219
Connecticut
2019 Mustang GT PP1, 401A, AE, B&O
Your entire post is exactly the same for me...all of it!
Fly2High
Long Island
Frank
2019 Mustang GT PP2
I think my 2019 PP2 is the same. I thought the passenger side was working and now it is not. For a minute I thought that it was not suppose to work to unlock, only lock.
It must have been an update:
go into Settings (click gears on steering wheel) -> Advanced Settings - >Vehicle -> Locks
In the door lock section is a feature called 'Inhibit Switch'.
It was checked. I never recall checking it. Once I unchecked it, the passenger side door handle responded to my touch to lock and unlock.
Let me know if this corrects it for you.
I am full of it. This is NOT the solution to the problem. it was pure coincidence. I unchecked it and I still had the issue. I do not drive the car much and had it sitting for a couple days. I got in and started the car to help with charging the battery. Turned it off and the passenger side would not work to lock or unlock the door. .
Elp_jc
None
Now I'm going to check my car. Ha ha. I checked 'honk' and 'lights' when locking, and only lights work. I have to click twice the lock button for the horn to sound, but thought all Fords did that automatically. Similarly, the dash has a check box for DRLs on, and it was reported if you uncheck it, they stay on. Lo and behold, that's exactly the same on my car. Oh well, at least I like them on, so no issue for me :D.
ivantwilliams
Georgia, USA
2018 Mustang GT Premium with Performance Package
I had a similar issue. But, it only happens if the car goes the sleep mode. And the Ford Pass app states it went into sleep mode (not enough driving of the car).
Rod27
St. Louis, Missouri
So it seems to be working for now, I didn't even adjust the settings. So how long would the mustang take to go into sleep mode? If a few hours then that may be the problem, but if it is several days, then the issue must be in the settings or something else.
Elp_jc
None
Just thought that it could be the battery on the keyfob getting low. Ford keyfobs eat batteries quicker than other cars, in my experience, and the F-150 fob was identical to the Mustang's. Try that, and see if that helps.
BigBeed
South Jersey
2019 GT Premium 401a PP2
I had the same issue. I disconnected my battery to install the leads for my battery tender and when I hooked the battery back up everything went back to normal. Try the ye old disconnect power wait 10 mins and reconnect it routine.
Torched10
Atlanta
Bob
That why I don't do auto updates
.they change things that don't need changing
ivantwilliams
Georgia, USA
It the car is not driven long, daily, that would cause sleep mode.
In my case, I drive 17 miles to work. Then the car sits for 8-9 hours, then 17 miles back home. Within a day or so, I get the sleep mode notification. If driving for ā€˜hours’, daily, you’d probably rarely get the sleep mode notification via the Ford Pass app.
This is merely my observation, i.e. my use case...
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
That's weird I drive about 30 miles each way and my car sits for 10 hours and I dont get any notifications. Also on weekends I dont drive it as I use my wife's car. Car normally sits unused from friday 6pm until monday 6:30am
m3incorp
Georgia/Colorado
James
I've never gotten the sleep mode. Last week I didn't drive the car Monday-Friday and didn't get it then either.
Soulja4187
Greenacres, FL
David
I think this option is for when you leave the windows down and you lock the car people cant unlock your door with the switch. I will search the owner's manual.
