bmoore1488
whodafuk
So this weekend I finally got around to installing these products in my IRS:
BMR Alum. Diff bushing
BMR Delrin cradle bushing
BMR LCA Bearings
BMR Toe rods
Ford racing toe to knuckle bearings
BMR Vertical links
So I take it for a test drive this morning and every time i push the clutch in when the car is moving it makes a clunking sound and then does it again when i release the clutch. I does not make the clunking/rattling sound when the car is still, its almost like when you take the load on and off of the car it does it. It will also do it if i'm cruising slow and tap on the gas and let off quick. Anyone got any Ideas, I've already went back and re torqued all the bolts and can't figure this thing out.
Also on a side note, does anyone know on the BMR toe rods which side the wider spacer goes on, on the inside? I put it on the aft side but after looking at it today it looks like it may be better on the fwd side to give more clearance on the mount.
BMR tech please feel free to step in here.
Thanks
BMR LCA Bearings
BMR Toe rods
BMR Vertical links
Thanks
