BMR CB005 issue
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
I meant to comment on here a couple weeks ago, but forgot. I installed the CB005 kit as well as the black steeda diff bushing support kit. I have zero wheel hop now. I can't find any situation where I can make the rear end hop. Everything feels more planted and firm out back. I have no real added NVH. If I have the windows up and the radio off, I can hear a slight gear whine, but nothing that would get annoying on a long drive, and I am sure that it is from the firm steeda bushings.. I did the install myself on jack stands and simple hand tools. Everything went together perfectly and I had zero issues.
-Jeff
This is why I recommend these parts so much - SUPER happy to see how well they worked out for you!
Nothing on the market compares to our CB005. It is a Grand Slam! :headbang:
As for the diff inserts, we will have our own poly inserts soon, thankfully.
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
Nice! Are you going to be implimenting the two bolt method for the front inserts like steeda? Or are you working on a more "straight forward" method? That front insert/washer/bolt was a PITA!
BMR Tech
Tampa, FL
Dion
The two bolt method like we use in our billet insert/lockout kit will likely be the route we take.
But, I have some other stuff in the works. :cheers:
CTH621
Asia
Mustang 2015 GT, 2022 Shelby GT500
Thanks for the feedback Kelly.... Yes I did do the diff mounts at the same time...
Think I'll leave it as is, for the moment, drive it a bit more and then come up with a plan...
What would be your advice on the issue below??
I fitted the 2 M8 bolts, and they pulled it to the body, but do you think it's worth loosening and putting a spacer underneath??
Andy, what did you end up doing with this gap?
