Installed: 10mm spacers and longer wheel studs
Mattwood440
Kodak, TN
2015 GT Base, Performance Package
+1. You need at least 8 threads for proper torque on an M14 bolt. I counted approximately 10 turns with the spacers and longer studs = perfect
cbass
Rochester, NY
God
2015 400a A6
I have open end lugs for the new wheels. I'll bring my internal calipers to see how much threading I get going on for the next test fit.
I wouldn't run spacers any thicker than 1 mm on OE studs.
Norm
Norm, I normally wouldn't run spacers at all, but the S197 wheels are too big to sell to most normal people, and I don't want to dick around shipping them. I'll buy something more normal sized over the winter, I think.
scott_0
Oxford, Pennsylvania
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
"Close, but no guitar" if you get the Philly morning show reference.
I needed to make up some spacers in 0.025" thickness (about 0.6mm) to eliminate a very tiny rub on the right front of the car the way it sits in my sig. Didn't have much left against a one bolt diameter minimum thread engagement.
Norm
cbass
Rochester, NY
God
2015 400a A6
So I ordered these studs from autozone this morning. Whoops.
It's like $21 shipped, so no big deal. I wonder if using my plastic HCR set will help, as the original pictures look like the hub was sticking out just a hair. Worst case, I can order a set of the rings in random internal sizes and check them out.
Lug nuts are already here, maybe the stud will get here around the same time as my spacers.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
factory studs can take up to 5 mm spacers while still getting the safest amount of turns, after that you need either extended studs and above 12 mm is a adapter.
MtnBiker
San Antonio, TX
2015 Mustang GT PP
I'm sure this install is fine. Options are good and the front hub is pretty easy to take off. I rent space in a shop when needed and they have a hydraulic press. I'll be using that for removal/install when I get some time. I'm going to use the Harbor Freight Ball Joint Separator to remove/install the rear studs. If that doesn't work I'll take that hub off too and use the press.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Sounds like your good man !
MtnBiker
San Antonio, TX
2015 Mustang GT PP
I'd be a little judicious about specifying a "safe" spacer thickness and focus on turns. Aftermarket rims and tuner lugs can leave you with less stud engagement. Optimally you'd have 1.5x stud diameter of threads engaged by the lug nut. I had 10.5 turns on my rims which might sound like a lot but is only .62" of engagement. That's not a lot at 148 lb/ft of torque. The ideal 1.5x would be .83" of engagement ... and that is before spacers. A 5mm spacer would take out about 30% of my already minimal thread engagement. My $.02
Mattwood440
Kodak, TN
What sucks is I couldn't find any 15mm bolt on adapters. I can't remember if I found one with a 70.3 center bore, but I found NONE with M14 studs. So that would mean 10 new studs, AND 10 new shorty lugs, and more labor. Maybe someone should look into manufacturing some <hint, hint>
MtnBiker
San Antonio, TX
2015 Mustang GT PP
As long as you are replacing studs why would you go with an adaptor vs a much stronger/safer spacer?
Mattwood440
Kodak, TN
Ease. The 1" adapters I put on the back were slick (no stud replacement necessary). I don't have any concern about their strength/safety. I know truck enthusiasts who use those bolt on adapters for some massive wheels and off roading.
Mattwood440
Kodak, TN
I have never heard of the "1.5 times the stud diameter" rule. That's 14 turns on a M14x1.5. Sounds high. That's more than Ford uses on the stock studs/lugs.
Anyone know for sure? Source? I'm sure there's an ISO formula somewhere.
Norm Peterson
Norm
'08 GT #85, '19 WRX
One of the concerns with adapters is how do you easily guarantee that the spacer to hub/axle flange nuts remain tight without removing the wheel and putting those fasteners through a lot of torque cycles?
I've also heard of the 1.5 x diameter rule of thumb before, but I don't recall where it came from.
Norm
