HP Tuner - How do I get a engine tune etc?
Turbo Cow
Turbo Cow
2021 GT
If it were me, I'd return it to the FRP tune. Then use PCMTec to read it and you can start making changes at will. Skip-shift is very easy to get rid of. If you want to discuss what does what, post your questions up here and we can discuss.
I tried to understand PCMTEC but there's so little info and the forums didn't seem too active. Plus isn't it expensive? Its like over 900 bucks right?
engineermike
La
2018 GTPP A10
Pcmtec is cheaper, around $150 for the software and another $150 for the dongle. It works similar to hptuners. It reads and writes the calibration and you can make changes. There are pros and cons to both. I have both but use Pcmtec 95% of the time.
Turbo Cow
Turbo Cow
2021 GT
Which one do you think is more user friendly?
Which one has more support?
It took me forever to learn the Holley EFI tuning software for my blown 90 mustang. I really want something simple. I'm just wanting to adjust transmission shift points. Maybe engine idle, some timing, stuff like that. Learning a new software that does more than what I need is just tiring at this point. I really don't know what to choose.
You can also use Forscan and tap the shift strategies to improve the feel…. If you haven’t, hit this main thread I posted a while back, many other 10R80 owners have helped to add to it with just 10R80 discussions.
in it, if you go to this link (Post 1, Page 1) and go to Fact #3, the linked threads are there for the Forscan info to tap the valve body shift strategies.
https://www.mustang6g.com/forums/th...tions-to-harsh-or-no-shift-conditions.135463/
The thread eventually ballooned with a ton of 10R80 info supplied by many users of this forum, so there may be other interesting or good info in it too if you have time to go through the pages of responses.
You can also search on this site by using “Forscan” and “10R80” as the 2 main search criteria for a single search and you’ll get a lot of thread results where others have DIY’ed the 10R80 shift points using that software modifier.
Hope that is helpful.
Turbo Cow
Turbo Cow
2021 GT
I wish I could use forscan but I searched for an hour on that thread and found nothing about modifying the 2nd gear skip. I searched the forum and found nothing pointing to instructions.
Turbo Cow
Turbo Cow
2021 GT
Question: With HP Tuner, can I set the different drive modes to have different tunes? Say Normal mode is 'normal' , sport mode shifts harder, maybe different idle rpm, and track mode has burble tune?
engineermike
La
2018 GTPP A10
Pedal torque response, shift firmness, shift rpm, and active exhaust position can all be changed as a function of drive mode, but that’s about it. Burble, using the stock logic, can only be activated in sport mode. There are workarounds here but they involve hacking up stuff.
Shepard
Gainesville, FL
Caleb
2018 Mustang GT PP1 400a A10
IMHO, HP Tuners is simpler and you'll have an easier time finding people's past experiences in tuning on the forums. They have a "basic" mode that shows the most commonly used parameters. It's more than enough for what you're looking for. It's also free to download and play with. For someone with prior tuning experience it should be easy. I'd second starting out with the FP Tune and just writing out the skip shift. There's a lot of forum help for it and the process is pretty trivial in hpt.
That said, PCMTec has a lot more features, offline flashing, and lower overall cost. There's no shortage of information and guides. There is a website where you can plug in hpt parameters and find the pcmtec equivalent which made it more enticing for me since I could use any guides and knowledge from hpt users in pcmtec.
> Old discussion - https://www.mustang6g.com/forums/threads/self-tuning-hpt-or-pcmtec.221739/
> Different drive modes can be set to have different shift maps completely. I know that engineermike was able to add burbles in sport mode https://www.mustang6g.com/forums/threads/mode-selection-and-tuning.212183/
> In sport mode, skip shift is generally disabled if you leave the stock impossible values in the skip shift columns. 1->3 can be fully disabled by swapping the "10,000" values in 1->2 to the 2->3 columns and moving the 1->3 values back over. You can do the same for the other modes (like drive "base"). This is a screenshot of hpt but you can convert values over to pcmtec if you decide to go with it and don't know where to look. https://hpttotec.com/
*This is someone else's file and I don't think skip shift is ever enabled on sport mode stock but I may be wrong? Hopefully it's still helpful.
Pistol_91
Clearwater
2020 mustang GT
Why don't you just contact Lund and see if they will accept your request? It sounds like you're about to go down a rabbit hole for something very simply done. If you aren't interested in tuning your car further than just a skip shift then I'd ask the tuner to change it.
Turbo Cow
Turbo Cow
2021 GT
So if I wanted to go with PCMTEC, is this all I need to purchase?
Shepard
Gainesville, FL
Caleb
There are only a few cables that they recommend. I've heard of some people trying others out with mixed success so I would choose one of these:
We have tested, support, and recommend the following J2534 Cables:
Rolls
Gold Sponsor
www.pcmtec.com
Mustang 18 GT
Rolls
Gold Sponsor
www.pcmtec.com
Mustang 18 GT
Technically any J2534 cable should work however most are professional scantools and thousands of dollars.
The Scanmatik, Peak, CarDaq, Ford VCM3 etc would be my picks but are $2k+ and the OBDX FT works just as well at a fraction of the price.
Turbo Cow
Turbo Cow
2021 GT
I'm still confused as to what software I need to purchase for PCMTEC. Is it the thousand dollar version if I want to tune my transmission also?
engineermike
La
2018 GTPP A10
No, the typical user only needs the ~$200 version to access engine and transmission. The transmission isn’t separate.
