How to line lock in a 6mt. Need some tips
airfuel
CT
Not a Bullitt
Take some videos of your first attempts!:popcorn:
sldghmr
MD
2015 GT PP, 2020 GT PP2, 2016 F-150 XLT
BREAKING NEWS
OP dead due to not wearing flame suit before posting.
I will be collecting donations for the family.
^^THIS^^ is just DAMN FUNNY!!! :lol::lol::lol:
To the OP, I had a lot of the same questions my first time using Line Loc also... I've done burnouts in the past with my other cars but could not grasp all of what the computer would do as far holding the brakes and for how long. I did know that I didn't want to bounce it off the rev limiter however....
RocketGuy3
2021 Mach 1 6MT, 2025 Cayman GT4 RS, 2025 RS3
As someone who has yet to try a burnout, this may be a dumb question, but... Why not?
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
If the engine has been fully broken in I wouldn't worry about it at all. The rev limiter is there for just that reason, to protect the engine.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Ford;
Giving it's Mustang owners easier ways of needing tires, clutches and transmissions since 2015.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
Ford;
if you need the line-lock feature you were going to do this anyway. Now you're just saving rear brake pads by not power-braking.
...of course, chances are you'd just rolled through water to break traction before heating your tires up if you do things correctly.
CBF_Deeb
Adelaide
2017 Shadow GT
Newbie question - Do the AUTO mustang GT's have line lock as well?
Falconetti
cash me outside howbow da
Boerne
2022 Mach 1, 1994 SVT COBRA
Make sure the number 1 item on your list in acheiving burn out heaven is setting up a camera and recording whatever it is that happens...then post here
nicktechla
Los Angeles, CA
www.nicktwaddell.com
Nick
2017 Camaro ZL1 Red Hot
I use 2nd gear
sldghmr
MD
IMHO, it's not something that I want to do to my engine for the fun of it...a missed shift/over rev every once in a while...ok, no problem. Knowing that our engines have pressed metal oil pump and crankshaft gears is bad enough. Look in the FI forum at how much they talk about harmonics.
Google 'bouncing off rev limiter' for yourself....more than 80% of what you read will be on the 'prob not a good idea' side of the house. Let me know what you think....
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
You know that's how lawn mowers work, right? Stay at the rev limiter until load slows them to max torque. If load exceeds max torque they stall.
In a lawn mower the governing weights actually will bounce. Nothing physically bounces in a Coyote. The rev limiter exists to keep the RPM well below the physical damage range. You can still damage things if you downshift too far while moving too fast, but Ford can't prevent your shift into 1st at 70 mph.
the OPG and timing sprocket see little increased load with higher RPM. At least I think you mean the timing sprocket by "crankshaft gear"... The OPG sees an increase in load with more viscous oil. So loads will be highest when cold or with a higher viscosity oil.
The timing sprocket would only see a significantly larger load from stiffer valve springs.
In short, it would do no damage to throttle up to the rev limiter and burn a tank of fuel... as long as you have cool air moving through the radiator.
